  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • zbrownZ
    zbrownZ
    PSiedTSi;326354 wrote:
    Get some more injector, newb. Just got my 950's in the other day.
    As soon as the manifold is done. 🙂
    I already have 1000s, lol
    big high Z injectors are $$$$, and a converter to low Z can suck my wee wee
    • PSiedTSiP
      PSiedTSiP
      Oh you nanner. Go buy some ID2000s and run your 8 ;).
      spanish-rice;237125 wrote:
      • zbrownZ
        zbrownZ
        Lol, the wife would notice that one
        all done
        car has about an inch of dust on it...needs to be driven
        • integra_gsr98I
          integra_gsr98I
          Did you finish the front half of the cage yet?
          • zbrownZ
            zbrownZ
            No
            I received my halo and A pillar bars. The halo fits nice, I don't like the A pillar
            So it wont be done till I buy a bender, don't know when that will be
            • DaveHD
              DaveHD
              I added all of my 25.5 bars myself, I just used a piece of 1/4" rod and bent it over my knee to make a pattern of the pipe I needed made, then brought the rod with me to the guy with the mandrel bender and had him make what I needed. You just need to find someone out in the backwoods where you live that has a bender. 🙂
              • zbrownZ
                zbrownZ
                sadly no one around here does. it is going to stay as is until i get my own bender 😞
                • zbrownZ
                  zbrownZ
                  changing a little bit of stuff
                  had a Magnafuel 625 (4301), and now got a new 750 (4303). This will support over 1kwhp on E85. Good pumps
                  and i plan to move my regulator up front at the same time trying to keep it not a hose monster. we will see how that goes
                  • zbrownZ
                    zbrownZ
                    gonna be along the lines of like this
                    and breathers, adding a -12 to each valve cover, and it will go back to the exhaust valvers with braided SS.
                    here is the baffles i added, this is the one in the valvecover i added last year. I added the same thing to the other side now with the addition of the other breather
                    • GarageAlchemistG
                      GarageAlchemistG
                      GarageAlchemist
                      Looks beast, as usual. Where are your coils hidden?
                      97 GTi, 03 KJ
                      • zbrownZ
                        zbrownZ
                        they are in mah cubby hole
                        you are going to have to get used to that whole 8 coil thing, lol
                        • zbrownZ
                          zbrownZ
                          and here is part of the plan so the fuel pressure sender is hidden and doesnt have to be down hanging off the regulator
                          • zbrownZ
                            zbrownZ
                            • zbrownZ
                              zbrownZ
                              well got my breathers and FPR done. i am waiting for a special order bend still to complete the passenger side rail > fpr line
                              I use all Earl's stuff now
                              engine bay hasn't been cleaned yet from last fall so, yes its dirty
                              -12 from each valve cover to exhaust valves
                              -6 from each rail into the FPR, -8 to the tank
                              and here is where the fuel pressure sender ended up
                              • zbrownZ
                                zbrownZ
                                The one harness really has bothered me for a time, so i ran alot of the wires under the intake to hide them, required some grinding
                                and then i put the correct terminals on for the injectors so that i didnt have to use the gayass adapters and chance a blown engine when one fucked up
                                also used good mesh looming
                                from this
                                to this
                                • legacy-user-3898L
                                  legacy-user-3898L
                                  legacy-user-3898
                                  looking good. when i did mine i ran wire's under the intake and tryed to keep it looking clean
                                  • zbrownZ
                                    zbrownZ
                                    just gonna update some stuff
                                    turbo is sold, dont know the replacement
                                    no more rock chips
                                    working on making the engine bay look nicer, the are not done
                                    new big boy 9.5" ptc
                                    and roll bar time, wanted something could bolt in and out and serviceable, no modding to tank mounting or anything
                                    • M
                                      M
                                      mat50ho
                                      Wire clean up Looks nice, I am intrestead to see how the new converter works...
                                      89 Mustang coupe
                                      • zbrownZ
                                        zbrownZ
                                        thanks man, i am excited too
                                        it will be interesting because it is amazing the car was running what it was as is.
                                        anyone there saw me puking oil on the topend and roasting my fluid, and pushing through the converter
                                        well problem was the stator support tube was pressed into the pump clocked wrong and the one oil passage was completely blocked off
                                        meaning no oil could leave the converter, haha
                                        • zbrownZ
                                          zbrownZ
                                          may be rice, but this excites me
