  4. New Stuff
New Stuff
461 Posts 56 Posters 70.9k Views
    zbrown;326355 wrote:
    I already have 1000s, lol
    big high Z injectors are $$$$, and a converter to low Z can suck my wee wee
    Oh you nanner. Go buy some ID2000s and run your 8 ;).
      Lol, the wife would notice that one
      all done
      car has about an inch of dust on it...needs to be driven
        Did you finish the front half of the cage yet?
          No
          I received my halo and A pillar bars. The halo fits nice, I don't like the A pillar
          So it wont be done till I buy a bender, don't know when that will be
            I added all of my 25.5 bars myself, I just used a piece of 1/4" rod and bent it over my knee to make a pattern of the pipe I needed made, then brought the rod with me to the guy with the mandrel bender and had him make what I needed. You just need to find someone out in the backwoods where you live that has a bender. 🙂
              sadly no one around here does. it is going to stay as is until i get my own bender 😞
                changing a little bit of stuff
                had a Magnafuel 625 (4301), and now got a new 750 (4303). This will support over 1kwhp on E85. Good pumps
                and i plan to move my regulator up front at the same time trying to keep it not a hose monster. we will see how that goes
                  gonna be along the lines of like this
                  and breathers, adding a -12 to each valve cover, and it will go back to the exhaust valvers with braided SS.
                  here is the baffles i added, this is the one in the valvecover i added last year. I added the same thing to the other side now with the addition of the other breather
                  • GarageAlchemistG Offline
                    GarageAlchemist
                    Looks beast, as usual. Where are your coils hidden?
                    97 GTi, 03 KJ
                      they are in mah cubby hole
                      you are going to have to get used to that whole 8 coil thing, lol
                        and here is part of the plan so the fuel pressure sender is hidden and doesnt have to be down hanging off the regulator
                            well got my breathers and FPR done. i am waiting for a special order bend still to complete the passenger side rail > fpr line
                            I use all Earl's stuff now
                            engine bay hasn't been cleaned yet from last fall so, yes its dirty
                            -12 from each valve cover to exhaust valves
                            -6 from each rail into the FPR, -8 to the tank
                            and here is where the fuel pressure sender ended up
                              The one harness really has bothered me for a time, so i ran alot of the wires under the intake to hide them, required some grinding
                              and then i put the correct terminals on for the injectors so that i didnt have to use the gayass adapters and chance a blown engine when one fucked up
                              also used good mesh looming
                              from this
                              to this
                              • legacy-user-3898L Offline
                                legacy-user-3898
                                looking good. when i did mine i ran wire's under the intake and tryed to keep it looking clean
                                  just gonna update some stuff
                                  turbo is sold, dont know the replacement
                                  no more rock chips
                                  working on making the engine bay look nicer, the are not done
                                  new big boy 9.5" ptc
                                  and roll bar time, wanted something could bolt in and out and serviceable, no modding to tank mounting or anything
                                  • M Offline
                                    M Offline
                                    mat50ho
                                    Wire clean up Looks nice, I am intrestead to see how the new converter works...
                                    89 Mustang coupe
                                      thanks man, i am excited too
                                      it will be interesting because it is amazing the car was running what it was as is.
                                      anyone there saw me puking oil on the topend and roasting my fluid, and pushing through the converter
                                      well problem was the stator support tube was pressed into the pump clocked wrong and the one oil passage was completely blocked off
                                      meaning no oil could leave the converter, haha
                                        may be rice, but this excites me
                                          legacy-user-3898
                                          looks nice. any idea's what size turbo your going to go with? i upgraded mine to a borg warner st80. did you make the rear sway bar yourself?
