  4. New Stuff
New Stuff
461 Posts 56 Posters 72.2k Views
    and here is part of the plan so the fuel pressure sender is hidden and doesnt have to be down hanging off the regulator
        well got my breathers and FPR done. i am waiting for a special order bend still to complete the passenger side rail > fpr line
        I use all Earl's stuff now
        engine bay hasn't been cleaned yet from last fall so, yes its dirty
        -12 from each valve cover to exhaust valves
        -6 from each rail into the FPR, -8 to the tank
        and here is where the fuel pressure sender ended up
          The one harness really has bothered me for a time, so i ran alot of the wires under the intake to hide them, required some grinding
          and then i put the correct terminals on for the injectors so that i didnt have to use the gayass adapters and chance a blown engine when one fucked up
          also used good mesh looming
          from this
          to this
          • legacy-user-3898L Offline
            legacy-user-3898
            looking good. when i did mine i ran wire's under the intake and tryed to keep it looking clean
              just gonna update some stuff
              turbo is sold, dont know the replacement
              no more rock chips
              working on making the engine bay look nicer, the are not done
              new big boy 9.5" ptc
              and roll bar time, wanted something could bolt in and out and serviceable, no modding to tank mounting or anything
              • M Offline
                M Offline
                mat50ho
                Wire clean up Looks nice, I am intrestead to see how the new converter works...
                89 Mustang coupe
                  thanks man, i am excited too
                  it will be interesting because it is amazing the car was running what it was as is.
                  anyone there saw me puking oil on the topend and roasting my fluid, and pushing through the converter
                  well problem was the stator support tube was pressed into the pump clocked wrong and the one oil passage was completely blocked off
                  meaning no oil could leave the converter, haha
                    may be rice, but this excites me
                      legacy-user-3898
                      looks nice. any idea's what size turbo your going to go with? i upgraded mine to a borg warner st80. did you make the rear sway bar yourself?
                        thanks
                        yeah i built the bar, got the parts for it off mcmastercarr. love that place
                        mmm turbo will still probably be an 88 compressor, just bigger turbine, probably gt55 size turbine
                        i am a turbo whore, that is the only reason i am changing haha
                          Your PT114 is scheduled to be delivered today, I'll get it shipped out to you this afternoon.
                            it would be embarrassing how slow i would go on that 114, truth, haha
                              Your direct port spool up kit will be delivered later this week as well.
                                legacy-user-3898
                                Does the pt114 spool that slowly?
                                  Lol... well that seems to be what the fast guys do aye?? 😉
                                  Yeah they would use an F or G trim turbine at 130mm. It would roll once moving though haha
                                    and here is the idea, 3" of dust so maybe doesn't look the best in the pics but in real life really nice
                                      looks great!!
                                      • 63vette6 Offline
                                        63vette6 Offline
                                        63vette
                                        Why did you put the axle ARB mounts on the front of the tube and not on the preferable location, the top?
                                          King Ricer;327991 wrote:
                                          looks great!!
                                          Thanks man
                                          No room. I wasnt going to cut the floor out of the car or i might aswell back half it
                                          This is the one place possible to mount it and fit with the stock tank and no cutting on vehicle
