  4. New Stuff
New Stuff
461 Posts 56 Posters 77.5k Views
  • zbrownZ
    zbrownZ
    thanks
    yeah i built the bar, got the parts for it off mcmastercarr. love that place
    mmm turbo will still probably be an 88 compressor, just bigger turbine, probably gt55 size turbine
    i am a turbo whore, that is the only reason i am changing haha
    • DaveHD
      DaveHD
      Your PT114 is scheduled to be delivered today, I'll get it shipped out to you this afternoon.
      • zbrownZ
        zbrownZ
        it would be embarrassing how slow i would go on that 114, truth, haha
        • DaveHD
          DaveHD
          Your direct port spool up kit will be delivered later this week as well.
          • legacy-user-3898L
            legacy-user-3898L
            legacy-user-3898
            Does the pt114 spool that slowly?
            • zbrownZ
              zbrownZ
              Lol... well that seems to be what the fast guys do aye?? 😉
              Yeah they would use an F or G trim turbine at 130mm. It would roll once moving though haha
              • zbrownZ
                zbrownZ
                and here is the idea, 3" of dust so maybe doesn't look the best in the pics but in real life really nice
                • King RicerK
                  King RicerK
                  looks great!!
                  Trafik Jamz;299122 wrote:
                  • 63vette6
                    63vette6
                    63vette
                    Why did you put the axle ARB mounts on the front of the tube and not on the preferable location, the top?
                    • zbrownZ
                      zbrownZ
                      King Ricer;327991 wrote:
                      looks great!!
                      Thanks man
                      No room. I wasnt going to cut the floor out of the car or i might aswell back half it
                      This is the one place possible to mount it and fit with the stock tank and no cutting on vehicle
                      • legacy-user-3898L
                        legacy-user-3898L
                        legacy-user-3898
                        are you going for more of a show car or race car? lol looks good tho
                        • zbrownZ
                          zbrownZ
                          probably a little beefy but happy with how it is in there
                          and wheel turned to lock
                          • zbrownZ
                            zbrownZ
                            this big fucker came, it is way bigger than i thought it was going to be.... lucky it fits, sorta. haha
                            it weighs 46lbs, 29 of that is the turbine housing
                            the turbine is a bit ridiculous haha, 111mm turbine. has nice billet aluminum backing plate
                            also started on the charge piping. could of just got rid of the cross pipe, decided i wanted to keep it, i bent the pipe in where it is open flush with the channel iron and welded that too
                            charge pipe will come out of IC and up like so
                            • MisterCMKM
                              MisterCMKM
                              So does the car have more turbo than the truck yet?
                              thrash;315544 wrote:
                              Ford is back :)
                              • zbrownZ
                                zbrownZ
                                ha i made the cummins NA
                                love the way this turned out, makes me happy!
                                next is turbo, I am waiting on a t6 flange then it is game time
                                • zbrownZ
                                  zbrownZ
                                  got alot done
                                  first thing i did was build a drain box for the turbo, everybody likes a happy drainage, haha
                                  here we have the intercooler setup done
                                  turbo is all done and mounted, charge piping all done, intake done, exhaust is only thing left
                                  on the charge piping i used hump hoses since the charge pipes are short and i use rubber engine mounts
                                  i would usually weld the elbow on the turbo but i can pull the bearing housing and compressor out of the turbine housing if i would do that without dropping the IC
                                  not a biggie i guess, just an extra coupler, haha
                                  • blackcherryTSiB
                                    blackcherryTSiB
                                    blackcherryTSi
                                    Your stuff is so badass! I wish I had a quarter or the skills and dedication that you have lol never seen a drain box before, any worries with it filling up faster then it drains them backing up into the turbo?
                                    1995 Honda Civic
                                    • zbrownZ
                                      zbrownZ
                                      thanks man
                                      na the box will help drain capacity, give it more degassing area
                                      and was worried about having a new converter, functioning transmission and how it would get up on the brake with this 111mm turbine
                                      well it makes boost so it is a good deal
                                      NA it stalls at 3200rpm, but i can get it up on the brake
                                      I let out at 10psi
                                      car feels like it is on a whole different level when this comes up
                                      https://www.youtube.com/watch?v=p6eDhrAx4qw&feature=youtube_gdata_player
                                      • capitljC
                                        capitljC
                                        capitlj
                                        I bet it does, that's an awful lot of turbo in there.
                                        Mitch Hedberg wrote:
                                        2004 Impala LS 3.8
                                        • legacy-user-351L
                                          legacy-user-351L
                                          legacy-user-351
                                          Can't wait to see it run this summer!
                                          Turkeylord
                                          '05 Yamaha Zuma - Stock
