  4. New Stuff
New Stuff
461 Posts 56 Posters 74.8k Views
    DaveH;326360 wrote:
    I added all of my 25.5 bars myself, I just used a piece of 1/4" rod and bent it over my knee to make a pattern of the pipe I needed made, then brought the rod with me to the guy with the mandrel bender and had him make what I needed. You just need to find someone out in the backwoods where you live that has a bender. 🙂
    sadly no one around here does. it is going to stay as is until i get my own bender 😞
      changing a little bit of stuff
      had a Magnafuel 625 (4301), and now got a new 750 (4303). This will support over 1kwhp on E85. Good pumps
      and i plan to move my regulator up front at the same time trying to keep it not a hose monster. we will see how that goes
        gonna be along the lines of like this
        and breathers, adding a -12 to each valve cover, and it will go back to the exhaust valvers with braided SS.
        here is the baffles i added, this is the one in the valvecover i added last year. I added the same thing to the other side now with the addition of the other breather
        • GarageAlchemistG Offline
          GarageAlchemist
          Looks beast, as usual. Where are your coils hidden?
          97 GTi, 03 KJ
            they are in mah cubby hole
            you are going to have to get used to that whole 8 coil thing, lol
              and here is part of the plan so the fuel pressure sender is hidden and doesnt have to be down hanging off the regulator
                  well got my breathers and FPR done. i am waiting for a special order bend still to complete the passenger side rail > fpr line
                  I use all Earl's stuff now
                  engine bay hasn't been cleaned yet from last fall so, yes its dirty
                  -12 from each valve cover to exhaust valves
                  -6 from each rail into the FPR, -8 to the tank
                  and here is where the fuel pressure sender ended up
                    The one harness really has bothered me for a time, so i ran alot of the wires under the intake to hide them, required some grinding
                    and then i put the correct terminals on for the injectors so that i didnt have to use the gayass adapters and chance a blown engine when one fucked up
                    also used good mesh looming
                    from this
                    to this
                    • legacy-user-3898L Offline
                      legacy-user-3898
                      looking good. when i did mine i ran wire's under the intake and tryed to keep it looking clean
                        just gonna update some stuff
                        turbo is sold, dont know the replacement
                        no more rock chips
                        working on making the engine bay look nicer, the are not done
                        new big boy 9.5" ptc
                        and roll bar time, wanted something could bolt in and out and serviceable, no modding to tank mounting or anything
                        • M Offline
                          M Offline
                          mat50ho
                          Wire clean up Looks nice, I am intrestead to see how the new converter works...
                          89 Mustang coupe
                            thanks man, i am excited too
                            it will be interesting because it is amazing the car was running what it was as is.
                            anyone there saw me puking oil on the topend and roasting my fluid, and pushing through the converter
                            well problem was the stator support tube was pressed into the pump clocked wrong and the one oil passage was completely blocked off
                            meaning no oil could leave the converter, haha
                              may be rice, but this excites me
                                legacy-user-3898
                                looks nice. any idea's what size turbo your going to go with? i upgraded mine to a borg warner st80. did you make the rear sway bar yourself?
                                  thanks
                                  yeah i built the bar, got the parts for it off mcmastercarr. love that place
                                  mmm turbo will still probably be an 88 compressor, just bigger turbine, probably gt55 size turbine
                                  i am a turbo whore, that is the only reason i am changing haha
                                    Your PT114 is scheduled to be delivered today, I'll get it shipped out to you this afternoon.
                                      it would be embarrassing how slow i would go on that 114, truth, haha
                                        Your direct port spool up kit will be delivered later this week as well.
                                          legacy-user-3898
                                          Does the pt114 spool that slowly?
