  4. New Stuff
New Stuff
461 Posts 56 Posters 69.6k Views
    Did you finish the front half of the cage yet?
    • zbrownZ Offline
      zbrownZ Offline
      No
      I received my halo and A pillar bars. The halo fits nice, I don't like the A pillar
      So it wont be done till I buy a bender, don't know when that will be
      rx7-8.89@157mph
      12v dodge, twins
      • DaveHD Offline
        DaveHD Offline
        DaveH
        I added all of my 25.5 bars myself, I just used a piece of 1/4" rod and bent it over my knee to make a pattern of the pipe I needed made, then brought the rod with me to the guy with the mandrel bender and had him make what I needed. You just need to find someone out in the backwoods where you live that has a bender. 🙂
        DaveH
        '94 Supra- 7.77 @ 176mph
        • zbrownZ Offline
          zbrownZ Offline
          sadly no one around here does. it is going to stay as is until i get my own bender 😞
          rx7-8.89@157mph
          12v dodge, twins
          • zbrownZ Offline
            zbrownZ Offline
            changing a little bit of stuff
            had a Magnafuel 625 (4301), and now got a new 750 (4303). This will support over 1kwhp on E85. Good pumps
            and i plan to move my regulator up front at the same time trying to keep it not a hose monster. we will see how that goes
            rx7-8.89@157mph
            12v dodge, twins
            • zbrownZ Offline
              zbrownZ Offline
              gonna be along the lines of like this
              and breathers, adding a -12 to each valve cover, and it will go back to the exhaust valvers with braided SS.
              here is the baffles i added, this is the one in the valvecover i added last year. I added the same thing to the other side now with the addition of the other breather
              rx7-8.89@157mph
              12v dodge, twins
              • GarageAlchemistG Offline
                GarageAlchemist
                Looks beast, as usual. Where are your coils hidden?
                97 GTi, 03 KJ
                • zbrownZ Offline
                  zbrownZ Offline
                  they are in mah cubby hole
                  you are going to have to get used to that whole 8 coil thing, lol
                  rx7-8.89@157mph
                  12v dodge, twins
                  • zbrownZ Offline
                    zbrownZ Offline
                    and here is part of the plan so the fuel pressure sender is hidden and doesnt have to be down hanging off the regulator
                    rx7-8.89@157mph
                    12v dodge, twins
                    • zbrownZ Offline
                      zbrownZ Offline
                      rx7-8.89@157mph
                      12v dodge, twins
                      • zbrownZ Offline
                        zbrownZ Offline
                        well got my breathers and FPR done. i am waiting for a special order bend still to complete the passenger side rail > fpr line
                        I use all Earl's stuff now
                        engine bay hasn't been cleaned yet from last fall so, yes its dirty
                        -12 from each valve cover to exhaust valves
                        -6 from each rail into the FPR, -8 to the tank
                        and here is where the fuel pressure sender ended up
                        rx7-8.89@157mph
                        12v dodge, twins
                        • zbrownZ Offline
                          zbrownZ Offline
                          The one harness really has bothered me for a time, so i ran alot of the wires under the intake to hide them, required some grinding
                          and then i put the correct terminals on for the injectors so that i didnt have to use the gayass adapters and chance a blown engine when one fucked up
                          also used good mesh looming
                          from this
                          to this
                          rx7-8.89@157mph
                          12v dodge, twins
                          • legacy-user-3898L Offline
                            legacy-user-3898
                            looking good. when i did mine i ran wire's under the intake and tryed to keep it looking clean
                            • zbrownZ Offline
                              zbrownZ Offline
                              just gonna update some stuff
                              turbo is sold, dont know the replacement
                              no more rock chips
                              working on making the engine bay look nicer, the are not done
                              new big boy 9.5" ptc
                              and roll bar time, wanted something could bolt in and out and serviceable, no modding to tank mounting or anything
                              rx7-8.89@157mph
                              12v dodge, twins
                              • M Offline
                                M Offline
                                mat50ho
                                Wire clean up Looks nice, I am intrestead to see how the new converter works...
                                89 Mustang coupe
                                • zbrownZ Offline
                                  zbrownZ Offline
                                  thanks man, i am excited too
                                  it will be interesting because it is amazing the car was running what it was as is.
                                  anyone there saw me puking oil on the topend and roasting my fluid, and pushing through the converter
                                  well problem was the stator support tube was pressed into the pump clocked wrong and the one oil passage was completely blocked off
                                  meaning no oil could leave the converter, haha
                                  rx7-8.89@157mph
                                  12v dodge, twins
                                  • zbrownZ Offline
                                    zbrownZ Offline
                                    may be rice, but this excites me
                                    rx7-8.89@157mph
                                    12v dodge, twins
                                      legacy-user-3898
                                      looks nice. any idea's what size turbo your going to go with? i upgraded mine to a borg warner st80. did you make the rear sway bar yourself?
                                      • zbrownZ Offline
                                        zbrownZ Offline
                                        thanks
                                        yeah i built the bar, got the parts for it off mcmastercarr. love that place
                                        mmm turbo will still probably be an 88 compressor, just bigger turbine, probably gt55 size turbine
                                        i am a turbo whore, that is the only reason i am changing haha
                                        rx7-8.89@157mph
                                        12v dodge, twins
                                        • DaveHD Offline
                                          DaveHD Offline
                                          DaveH
                                          Your PT114 is scheduled to be delivered today, I'll get it shipped out to you this afternoon.
                                          DaveH
