  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 53.1k Views
  • XJHEADX Offline
    XJHEADX Offline
    XJHEAD
    DaveH;260380 wrote:
    Looks like you better order up a wheelie bar kit... and a case of Depends.
    New tires showed up yesterday
    Old vs new, about the same width 11.75" on the ground.
    7.64 @ 187 3400 lbs. on KORN
    TTSBF
    RTCTTFMF PTOSITW
    • DaveHD Offline
      DaveHD Offline
      DaveH
      Starting to get some Man-sized tires I see. We should set them next to one of my 33's, would be interesting to see the difference.
      DaveH
      '94 Supra- 7.77 @ 176mph
      • 63vette6 Offline
        63vette6 Offline
        63vette
        Racing on drag radials is like drifting an import without the control.. 🙂
        • XJHEADX Offline
          XJHEADX Offline
          XJHEAD
          Notching the frame for new spring pockets.
          TTSBF
          RTCTTFMF PTOSITW
          • XJHEADX Offline
            XJHEADX Offline
            XJHEAD
            Got a little more done.
            This is what the stock mount looks like. Large spring with perch on the outside of the frame-rail.
            TTSBF
            RTCTTFMF PTOSITW
            • XJHEADX Offline
              XJHEADX Offline
              XJHEAD
              And this is still called stock suspension. lol
              TTSBF
              RTCTTFMF PTOSITW
              • funky_monkey58F Offline
                funky_monkey58
                Looks stock to me.
                • DaveHD Offline
                  DaveHD Offline
                  DaveH
                  Moving the spring in just gives you room for a bigger tire right?
                  DaveH
                  • XJHEADX Offline
                    XJHEADX Offline
                    XJHEAD
                    Yes, that is the only reason why I am doing it. I cannot go to a coil-over.
                    TTSBF
                    RTCTTFMF PTOSITW
                    • XJHEADX Offline
                      XJHEADX Offline
                      XJHEAD
                      TTSBF
                      RTCTTFMF PTOSITW
                      • XJHEADX Offline
                        XJHEADX Offline
                        XJHEAD
                        New shocks finally showed up. Everything for the mini-tub is almost complete. Now I just need to order some new wheels to tuck the tires in some more..
                        TTSBF
                        RTCTTFMF PTOSITW
                        • XJHEADX Offline
                          XJHEADX Offline
                          XJHEAD
                          Stripped everything off the bottom of the car and gave it a quick spray. Looks much nicer than flat black.
                          TTSBF
                          RTCTTFMF PTOSITW
                          • DaveHD Offline
                            DaveHD Offline
                            DaveH
                            Strange shocks this time?
                            DaveH
                            • XJHEADX Offline
                              XJHEADX Offline
                              XJHEAD
                              Yep, they were quite a bit cheaper than a set of Afco's.
                              TTSBF
                              RTCTTFMF PTOSITW
                              • XJHEADX Offline
                                XJHEADX Offline
                                XJHEAD
                                Mini-tub is almost all complete. Just a little bit of the tubs are showing. I may switch the seat carpet to black. Haven't decided yet, whatcha think?
                                TTSBF
                                RTCTTFMF PTOSITW
                                • GrrG Offline
                                  GrrG Offline
                                  Grr
                                  looks HACK!!
                                  that carpet does look kind of out of place i guess, not that i would care
                                  BTW i was thinking today, how extensive is your fire supression system on that? Just engine bay or multi zone
                                  2006 Trailblazer SS- my DD
                                  • XJHEADX Offline
                                    XJHEADX Offline
                                    XJHEAD
                                    Grr;305009 wrote:
                                    looks HACK!!
                                    Sad thing is I haven't installed it yet. It is going in this winter. It has 2 lines off the head. One will go to a 360* nozzle and the other will go to 2-180* nozzles. There are conflicting ides on where to mount them. I think they all should be in the engine bay. Some like one in car in front of you.
                                    TTSBF
                                    RTCTTFMF PTOSITW
                                    • DaveHD Offline
                                      DaveHD Offline
                                      DaveH
                                      Better keep the carpet, otherwise you know someone at BIR will claim the interior isn't "finished" enough looking.
                                      DaveH
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        XJHEAD
                                        Big things can come in small packages.
                                        TTSBF
                                        RTCTTFMF PTOSITW
                                          Those got shipped to the wrong place I believe! My grandpa is missing the sprayer heads for his new center pivot on his farm.
