  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 53.1k Views
  • zbrownZ Offline
    zbrownZ Offline
    63vette;262511 wrote:
    Etiquette/respect....goes a long way these days.
    :icon_scratch:
    rx7-8.89@157mph
    12v dodge, twins
    • zbrownZ Offline
      zbrownZ Offline
      Don**'**t you have spelling 101 in the morning? Go to bed Nancy.
      fixed
      Maybe he had a typo on his Blackberry?.... that never happens to Mr. 7 sec. though does it?
      rx7-8.89@157mph
      12v dodge, twins
        63vette is fiesty tonight
        • fallguyF Offline
          fallguyF Offline
          fallguy
          The funny thing is that if they met each other at the track they prolly would get along famously. 🙂
          1990 Ford Probe GT 2jz RWD
            Ya guys, I thinks this has been blown way out of proportion. I blame Bill for this. Stop starting fast car threads.
              I blame Chuck.
              • XJHEADX Offline
                XJHEADX Offline
                XJHEAD
                So anyways, I was sanding down the header flange this am and just smoked checked my 6"X48" belt sander. Time for a new motor. I think I'll to get a 1 hp instead of the 3/4 hp in there.
                7.64 @ 187 3400 lbs. on KORN
                TTSBF
                RTCTTFMF PTOSITW
                • BassplayerB Offline
                  BassplayerB Offline
                  Bassplayer
                  Baller :icon_rr:
                  1995 GMC Sierra
                    just boost it...
                    • XJHEADX Offline
                      XJHEADX Offline
                      XJHEAD
                      One side welded up.. Notice I took the picture a safe distance aways.:icon_brilsmurf:
                      TTSBF
                      RTCTTFMF PTOSITW
                        Good idea, i'm sure Joel would mock your welding and try to prove his is better or something...
                        • zbrownZ Offline
                          zbrownZ Offline
                          LOL, I'd have to say it looks darn good from here still though
                          rx7-8.89@157mph
                          12v dodge, twins
                          • XJHEADX Offline
                            XJHEADX Offline
                            XJHEAD
                            Anyone see a problem with the placement like this???
                            TTSBF
                            RTCTTFMF PTOSITW
                            • zbrownZ Offline
                              zbrownZ Offline
                              could you have bearing issues like that possibly?
                              rx7-8.89@157mph
                              12v dodge, twins
                              • XJHEADX Offline
                                XJHEADX Offline
                                XJHEAD
                                Never thought of that. The drain will still be on the bottom.
                                Here are some close up welds. These are about as good as I get. Give me some 1/4"+ plate and a stick welder.
                                TTSBF
                                RTCTTFMF PTOSITW
                                  Here are some close up welds. These are about as good as I get. Give some 1/4" plate and a stick welder.
                                  Those pics are mighty small but thats damn good for a stick welder. Looks like you might have a little bit of undercut on the top.
                                    Bill:
                                    Turbos should be ok to ~30 degrees of tilt. I'd imagine you won't have much of an issue at that angle.
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      XJHEAD
                                      I was chatting with the owner of this car last night. He had the same concept in a 57' and built this vehicle. He said he has no problems whatsoever. His are mounted 30* , mine wil be about 20*.
                                      TTSBF
                                      RTCTTFMF PTOSITW
                                      • zbrownZ Offline
                                        zbrownZ Offline
                                        I definitely like the way you have them oriented in there though.... looks hot
                                        rx7-8.89@157mph
                                        12v dodge, twins
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          XJHEAD
                                          I thought it looked pretty good too. I got one side all welded up. Still need to add the w/g and start the other side. I'll have to move the inlet on the radiator now.
                                          TTSBF
                                          RTCTTFMF PTOSITW
