  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 50.1k Views
  • XJHEADX Offline
    XJHEADX Offline
    XJHEAD
    63vette;260621 wrote:
    with or without the blades engaged?
    sorry...but you had to see it coming....
    KUBOTA ORANGE BABY!!!!
    That was without, only 165 engaged.
    Anyways, got a little done. Glad I didn't open any beers while you guys were here, never would have gotten anything done.
    Cobra bay
    7.64 @ 187 3400 lbs. on KORN
    TTSBF
    RTCTTFMF PTOSITW
    • zbrownZ Offline
      zbrownZ Offline
      how did everything look in the motor?? better or worse than you expected??
      rx7-8.89@157mph
      12v dodge, twins
      • 63vette6 Offline
        63vette6 Offline
        63vette
        Wow, you did get a lot done!
        • XJHEADX Offline
          XJHEADX Offline
          XJHEAD
          Only thing I thought was odd was the intake runners in the head had some tar-like sludge on the bottom of them. I think it may be too rich at part throttle cruising. It always felt like it wanted to stumble when cruising around. Besides that everything else looks good. I thought it would be a little cleaner on the valves. But not bad for what it has been through. 150+ dyno pulls, 40 or so passes last year and who knows how miles Andy put on it while it was down in SD. I always wondered why the back seat stunk.
          TTSBF
          RTCTTFMF PTOSITW
          • 63vette6 Offline
            63vette6 Offline
            63vette
            valve timing was off a hair.
            • 63vette6 Offline
              63vette6 Offline
              63vette
              no avatar wtf???
              ahhhhhh thats better.. 🙂
              • DaveHD Offline
                DaveHD Offline
                DaveH
                XJHEAD;260630 wrote:
                Only thing I thought was odd was the intake runners in the head had some tar-like sludge on the bottom of them. I think it may be too rich at part throttle cruising. It always felt like it wanted to stumble when cruising around. Besides that everything else looks good. I thought it would be a little cleaner on the valves. But not bad for what it has been through. 150+ dyno pulls, 40 or so passes last year and who knows how miles Andy put on it while it was down in SD. I always wondered why the back seat stunk.legacy image
                E98 will clean those valves right up. Mine looked cleaner after running all season than they did when I put them in.
                DaveH
                '94 Supra- 7.77 @ 176mph
                • z31Z Offline
                  z31Z Offline
                  z31
                  Here is the before picture. :icon_bigsmurf:
                  • XJHEADX Offline
                    XJHEADX Offline
                    XJHEAD
                    Took about 40+ lbs out last night and today. Everything else is pretty much stripped already.
                    TTSBF
                    RTCTTFMF PTOSITW
                    • XJHEADX Offline
                      XJHEADX Offline
                      XJHEAD
                      Just weighed the car;
                      No engine
                      No Tranny
                      No Fuel
                      No turbo/exhaust
                      2025 lbs. should be right around 3100 lbs. when back together.
                      TTSBF
                      RTCTTFMF PTOSITW
                      • DaveHD Offline
                        DaveHD Offline
                        DaveH
                        No engine
                        No Tranny
                        No Fuel
                        No turbo/exhaust
                        So 3350 lb with driver?
                        DaveH
                        • XJHEADX Offline
                          XJHEADX Offline
                          XJHEAD
                          Watcha trying to say???
                          3100 with driver
                          :ford: rulz this year................................
                          TTSBF
                          RTCTTFMF PTOSITW
                          • 63vette6 Offline
                            63vette6 Offline
                            63vette
                            How much does your new bruno/lenco weigh? 🙂
                            • XJHEADX Offline
                              XJHEADX Offline
                              XJHEAD
                              So yesterday I was putting in the mock-up motor into the car. Put the tranny back in too and saw this.
                              The K-member cross bar sits higher than my Cobra one. Leaves the pan just exposed. If I pull a DaveH it won't be pretty.
                              I pulled it out last night and today pulled the one out of the Cobra and put it in. Looks much better. Motor isn't all the way dropped in on the drivers side that is why it is a little crooked.
                              TTSBF
                              RTCTTFMF PTOSITW
                              • 63vette6 Offline
                                63vette6 Offline
                                63vette
                                Whats the measurement of your crank c/l at ride height?
                                • z31Z Offline
                                  z31Z Offline
                                  z31
                                  Good idea. :icon_bigsmurf:
                                  • XJHEADX Offline
                                    XJHEADX Offline
                                    XJHEAD
                                    I have it written down somewhere for the cobra. I won't be able to get you a number until I get everything installed and set my suspension up. My best guess would be somewhere around 17-18".
                                    TTSBF
                                    RTCTTFMF PTOSITW
                                    • 63vette6 Offline
                                      63vette6 Offline
                                      63vette
                                      Being this is a lot lighter car you may want to lower that a couple inches if possible, or get really beefy wheelie bars.
                                      You are getting it done though thats for sure. That thing ought to be running by next week.
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        XJHEAD
                                        The only way I could lower is if I relocate the steering rack.. It is possible, just some welding. I may ditch my motor mounts and go solids or motor plates. I was stretching the steal apart on my Energy Suspension ones.
                                        EDIT; wheelie bars are for sissies
                                        I have the top left ones in the pict. The outer shell was being pulled apart
                                        TTSBF
                                        RTCTTFMF PTOSITW
                                        • 63vette6 Offline
                                          63vette6 Offline
                                          63vette
                                          Ohhh here we go with the wheelie bar - sissy argument again.
                                          Wheelie bars are a safety device to me. Its got nothing to do with balls. On a 9 second car...errr no. On your car....yes. Get it all dialed in on our greasy little track then take it somewhere that hooks, when everything forward of the firewall is destroyed I will buy you a beer and get to say I told you so. 🙂
                                          Im just sayin....
