  4. Dave, Matt, Bill
Dave, Matt, Bill
53 Posts 17 Posters 4.8k Views
  • ChristianC Offline
    ChristianC Offline
    Christian
    -10 AN for me too and -8 back . Just do it right the first time so you only have to do it once.
    Playtime Performance
    93 Mustang 6.0l ... 9.99 @ 136
    06 F-150 Lariat
    • XJHEADX Offline
      XJHEADX Offline
      XJHEAD
      zbrown;297065 wrote:
      What regulators for you guys, and do you have a filter pre and post pump?
      I had the Aeromotive on the Cobra, when I had two pumps on that it was not returning enough of the fuel to the return line. I borrowed Dave's Weldon and it cleared that right up. The Orange car had a Weldon on it. With both pumps running base pressure goes up maybe 2-3 lbs at idle. Either one should be fine. Also run two filters, one before the pump and one after.
      Please read the quote below..:icon_rabbit:
      I should have just named this thread ..."the really fast guys' fuel systems" haha
      thanks
      7.64 @ 187 3400 lbs. on KORN
      TTSBF
      RTCTTFMF PTOSITW
      • zbrownZ Offline
        zbrownZ Offline
        You guys run and bend hardline the length of the car or just run SS braided the whole way up?
        thanks for the input:icon_thumleft:
        rx7-8.89@157mph
        12v dodge, twins
        • DaveHD Offline
          DaveHD Offline
          DaveH
          I run an Aeromotive Pro pre-filter and a Aeromitive standard post filter. Braided line the whole way, no hardlines.
          I have -12AN line from the fuel cell to the pump, then -10AN from the pump up to the engine bay, I have a Y-block in the engine bay where it splits to two -8AN lines and each -8AN line goes to an end of the fuel rail. I got the Weldon 2040 regulator.
          DaveH
          '94 Supra- 7.77 @ 176mph
          • XJHEADX Offline
            XJHEADX Offline
            XJHEAD
            Aeroquip Push-lock is a cheaper alternative from cell/tank to the engine bay. It is a very durable hose.
            http://www.aeroquip.cc/fbv0800fc332-08aeroquipsocketlesspush-onhosehightempfc332-8.aspx
            TTSBF
            RTCTTFMF PTOSITW
              XJHEAD;296969 wrote:
              I have a Weldon 2035. Pressure started dropping at about 1250 rwhp at the track. I added my old Accel DFI pump that I used on the Cobra. It flows about the same as the 2035. They aren't too bad if mounted properly. Here is the video of the Weldon that was bolted right to the car with no isolators.
              http://www.youtube.com/watch?v=8Qc07FKciTc
              If I can make room I am going belt drive this winter.. I don't like the idea of two pumps.
              Sounds like tornado sirens. :fork:
                Parker;296974 wrote:
                Silly electronic fuel pumps...
                Silly carburetors
                • zbrownZ Offline
                  zbrownZ Offline
                  thanks
                  I have always wondered about the push-lock stuff, never knew if it was any good so i have never tried it
                  maybe I'll give it a try, thanks
                  rx7-8.89@157mph
                  12v dodge, twins
                  • ParkerP Offline
                    ParkerP Offline
                    Parker
                    push lock works very good...
                    10 Jeep
                    10 F450
                    08 F250
                    05 F350
                    86 rx7
                    70 F100
                    63 Olds
                    > BlueSRT0483;244555 wrote:
                    > Trafik Jamz;260984 wrote:
                    > You are right Parker.
                    • zbrownZ Offline
                      zbrownZ Offline
                      Parker;297153 wrote:
                      push lock works very well...
                      fxt
                      rx7-8.89@157mph
                      12v dodge, twins
                      • ParkerP Offline
                        ParkerP Offline
                        Parker
                        zbrown;297158 wrote:
                        fxt
                        Oh, you got me good fucker.....
                        10 Jeep
                        10 F450
                        08 F250
                        05 F350
                        86 rx7
                        70 F100
                        63 Olds
                          Stupid farmers...
                          • 00Ws6TransAm0 Offline
                            00Ws6TransAm
                            zbrown;296962 wrote:
                            How loud are the Weldon pumps? is the pump like you have good for continuous use or no?
                            I picked up a Magnafuel 4301
                            Any of you heard good or bad about these pumps?
                            FWIW
                            I have been using that exact pump for the last 2 years. It is a great pump, I had one issue with it overheating, but after sending it in and them fixing for free its been flawless. It was 95 when it overheated, i havent heard of such problems with other users though. There was older style wear plates in there that expanded and locked it up when overly hot.
                            I have a 74micron pre filter and a 40micron post filter. I have part #'s if you want and it will save you money buying direct rather than through a vendor.
                            -8feed and -6 return (Stainless all the way)
                            Line runs in one rail across the front through the other, out the back,and into the magnafuel fuel pressure regulator.
                            Depending on your power goals you may want to increase line sizes.
                            • zbrownZ Offline
                              zbrownZ Offline
                              00Ws6TransAm;297656 wrote:
                              FWIW
                              thanks for the info! glad to hear you have had good luck with it.
                              I already picked up my plumbing supplies sadly 😞 ... got a magnafuel 74 micron and 10 micron filters... and the big magnafuel 9950 regulator with -8 return
                              some of you may think i am retarded but i plan to run my regulator in the back of the car....going to run a high static fuel pressure and un-referenced.
                              I like the simplicity in the engine bay with no fuel plumbing there... i will see how it works like that, i can always change to referenced
                              will be -10 to the pump... -8 to the FPR.... -8 from FPR up to the front rail... and a -8 return from the FPR right to the tank
                              -8 will support 1k hp.... I am not crazy like some of you guys so it will suffice 😉
                              rx7-8.89@157mph
                              12v dodge, twins
                              • XJHEADX Offline
                                XJHEADX Offline
                                XJHEAD
                                What fuel pressure are you going to run? How are you going to feed the rails?
                                TTSBF
                                RTCTTFMF PTOSITW
                                • zbrownZ Offline
                                  zbrownZ Offline
                                  IIRC most gm stuff is all now 58 psi
                                  I will probably start at around 65-70psi (the injectors i got are supposed to be great and happy at high pressures)
                                  if i run into heating the fuel too much i will stick a cooler in the return line because there is alot of room back there
                                  vette guys make as much power as i want on stock fuel lines with the stock unreferenced FPR in the back so i dont think i will have any problems at boost levels less than 15psi
                                  all i will have going forward is one -8 right up to the rail...
                                  rail will be modded like this with the addition of a -8 feed...(with stock feed cut off flush and plugged, though still acting as a cross over)
                                  So am i really retarded or just sorta?? haha
                                  rx7-8.89@157mph
                                  12v dodge, twins
                                  • D Offline
                                    D Offline
                                    dynotune
                                    gas or korn? ls1 intake or ls6? seen the fuel system thing done a whole buncha times, but why not boost reference it? 15 lbs on 370 in LS motor is a pile of power, 60s def wont cut it on korn with no boost reference... just my experience. The higher pressure you run on your pump, the faster it runs outta steam (exponentially) you probably know this, but fyi. If you are on gas, you wont get your fuel trims to settle on 60s at 65-70 base FP. If it is reference @ 58 it will work (50 psi @ idle) On E85 that set-up runs out about 560 (procharged, prob about 600+/- turbo)to the tire on a returnless. IIRC, that set-up is good for low 700s on gas.
                                    DynoTune Speed & Performance
                                    Custom EFI Programming for Ford, GM, and all others
                                    Mobile chassis dyno service
                                    www.dynotuneusa.com
                                    (605) 753-1101
                                      I think He plans on running 91 and a meth kit...
                                      • zbrownZ Offline
                                        zbrownZ Offline
                                        Thanks for the pointers Andy.
                                        It will be run on e85 and this is on a ls3/l92 topend
                                        maybe i will run a reference line right away then, what you say makes sense
                                        Plan was to make what power i could support on the 60's and be able to go to a bigger injector like some high imp. 90's or more... but already have the rest of the system ready to support some more hp.
                                        This thing is coming to you to get tuned so any ideas or criticisms are greatly appreciated on fuel and other aspects....
                                        the combo is a 370", TC78 1.15, TH350, 3.23 solid rear 8.8
                                        rx7-8.89@157mph
                                        12v dodge, twins
                                        • GrrG Offline
                                          GrrG Offline
                                          Grr
                                          send me your vette regulator, i was just gonna order one but ill buy your old shit instead, and any of your old FI line.
                                          You are gonna need injectors anyway and it will work fine running non referenced if you want, doubt you will ever take that car over 10psi anyway, it will be about undriveable. I ran my 65#ers out at 16psi on my buick on gas at 70psi base pressure and you know how fast that was, corn none of my fuel system would go over 12. You can get FIC high imp injectors (ball and seat, the good ones) as big as you want now so that wont be an issue
                                          2006 Trailblazer SS- my DD
