  3. Run Your Mouth
  4. I would like everyone's opinion
51 Posts 36 Posters 5.7k Views
  • FlowcusF Offline
    FlowcusF Offline
    Flowcus
    Import a Subaru Impreza STi Spec-C set it up for Tarmac Rally racing.
    Fully enclosed race trailer with generator and tools.
    2005 Dodge Cummins turbo diesel with Banks Siderwinder kit
    And the rest would be for fixing the subaru, paying for fuel, and my trips around the country to different races. ( the money would run out, but having an STi spec-C doing tarmac rally racing... your going to grab some sponsors somewhere )
    I ride random bitches.
      HandoEX wrote:
      "I'd have sex with two girls at the same time!"
      -Lawrence, Office Space
      I was going to say that same thing..
      I would throw some money at my car..probably quite a bit
      then,
      M3 + bling bling
      evo/sti + tons of tires and brakes
      F350 + "banks" and chrome
      GTI R32 + a TON of money
      boat + ski rope
      jet ski + trailer
      CBR + helmet and band aides
      • LightEmUpL Offline
        LightEmUpL Offline
        LightEmUp
        I would get.......
        1969 camaro Z28 RS/SS Copo
        That would put me about 750,000 over budget lol jk
        For real I would buy a
        1970 trans am (50,000)
        1970 GTO Judge (70,000)
        1067 Camaro RS/SS 454 (100,000)
        and the last 30,000 I would just have for extra money
        1975 Trans am 455 8.99 @158mph (What now fallguy)
        1987 CRSEX W/Fucking VVVVVVVVV-TEC (But is now sitting in a junk yard cuz I blew it up......Ooops!!)
        2001 cr125 (Faster Than LoveMachines Bike)
        • 3_Series3 Offline
          3_Series3 Offline
          3_Series
          Hennessey Venom 1000 Twin Turbo SRT Coupe (225,000)
          top speed 255mph! rest would be for gas.
          2002 Subaru Legacy
          1993 BMW 325i (sold)
          • FlowcusF Offline
            FlowcusF Offline
            Flowcus
            That car isnt real... the world record holder for top speed is the Koenigsagg CCR with 242mph. I have the Car and Driver with it in there... such a kick ass car!
              I'd keep my car, New shelby gt500, new ford gt There is enough there for parts and research work on I'd say 7 shelby's (any year)in restorable condition from the 60's.
              • 3_Series3 Offline
                3_Series3 Offline
                3_Series
                well the 255mph figure is theoretical of course, but i wouldn't bet against a car with 1000hp/1100tq if you give it enough pavement.
                2002 Subaru Legacy
                  My money is FIRMLY on the Koenigsegg CCR
                  Performance
                  Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds
                  Top speed: 395+ km/h (242+ mph)
                  Standing quartermile: 9 seconds, end speed 235 km/h (146 mph)
                  Braking distance: 31 m (100–0 km/h)
                  Lateral g-force: 1.3 g
                  Fuel consumption: Highway travel: 13 l/100 km
                  Combined: 17 l/100 km
                  Body
                  Two-door, two-seater with removable hardtop stowable under the front boot lid. 	The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam 	sandwich reinforcements.
                   	**Dimensions**
                  Ground clearance: 100 mm (3.9 inch)
                  Fuel capacity: 80 litres (17.6 gallons)
                  Luggage compartment: 120 litres (26.4 gallons)
                  Dry weight: 1180 kg
                  Areodynamics
                  Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis. 	Venturi tunnels at the rear of chassis/body.
                  Chassis
                  Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
                  Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
                  Brakes
                  Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
                  Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control syste
                  Wheels
                  Koenigsegg magnesium alloy wheels with centre locking.
                  Front: 19” x 9.5”
                  Rear: 20” x 12.5”
                  Tyres
                  Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
                  Front: 255/35–19” (Y)
                  Rear: 335/30–20” (Y)
                  Steering
                  Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres.
                  Engine (click for more info about the CCR engineering specifics)
                  Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
                  Displacement: 4.700 cm3.
                  Compression: 8.6:1
                  Weight: 215 kg
                  Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
                  Oil: SAE 10W60 fully synthetic racing.
                  Oil tank capacity: 12 litres (2.64 gallons)
                  Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.
                  Fuel: 98 RON unleaded.
                  Ignition system: Direct coil on plug. Transistorised.
                  Power output: 806 bhp at 6.900 rpm.
                  Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
                  Maximum rpm: 7.600 rpm.
                  Transmission
                  Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
                  Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch). Oil-cooled and electronically operated.
                  Equipment
                  In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
                  Standard equipment
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Aluminium rear light casings
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Detachable roof panel
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Climate control
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Electric rear view mirrors
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Leather interior
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Central locking
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Electrical windows
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Alarm with immobilizer
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Toolkit
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Driver side airbag
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Power steering
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Hydraulic ride height control
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Servo assisted brakes
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) ABS
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Traction control
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Stereo with CD-player
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Tyre pressure sensors
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Car cover
                  Customer options
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Custom Color Leather Interior
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Custom Paint Color
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Parking Sensors
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) GPS Navigation
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Sequentially operated gearbox
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Rearview Camera
                  ![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Fitted Luggage
                  Whats not to love?
                  • SaxGopherS Offline
                    SaxGopherS Offline
                    SaxGopher
                    Ariel Atom... just because...
                    With whatever's left over I think I'd try to find a FIA Rally-Spect WRC Evo 6.5... Either that or just import an Evo 6 TME and drop a few grand into that and buy a normal evo for a daily driver...
                    Or the Koenigsegg... yeah... that'd be sweet...
                    P.S. Anyone seen the Top Gear where he drove the Atom? A-freaking-mazing...
                    03 Evo VIII w/ bolt-ons. :icon_thumleft:
                      Well me, I always try to lean toward something a little different, something you don't see every day. It's a name we all know and love but it's type that's rarely seen.
                      Two words: "Oldschool" Skyline 😄
                      legacy image legacy image legacy image
                      Plus I'm sure I'd a few bucks left to build a garage to keep it in.
                      • 3_Series3 Offline
                        3_Series3 Offline
                        3_Series
                        Performance
                        Body
                          **Dimensions**
                        Dry weight: 1180 kg
                        Areodynamics
                        Chassis
                        Brakes
                        Wheels
                        Front: 19” x 9.5”
                        Rear: 20” x 12.5”
                        Tyres
                        Steering
                        Compression: 8.6:1
                        Weight: 215 kg
                        Transmission
                        Equipment
                        Standard equipment
                        legacy image Aluminium rear light casings
                        legacy image Detachable roof panel
                        legacy image Climate control
                        legacy image Electric rear view mirrors
                        legacy image Leather interior
                        legacy image Central locking
                        legacy image Electrical windows
                        legacy image Alarm with immobilizer
                        legacy image Toolkit
                        legacy image Driver side airbag
                        legacy image Power steering
                        legacy image Hydraulic ride height control
                        legacy image Servo assisted brakes
                        legacy image ABS
                        legacy image Traction control
                        legacy image Stereo with CD-player
                        legacy image Tyre pressure sensors
                        legacy image Car cover
                        Customer options
                        legacy image Custom Color Leather Interior
                        legacy image Custom Paint Color
                        legacy image Parking Sensors
                        legacy image GPS Navigation
                        legacy image Sequentially operated gearbox
                        legacy image Rearview Camera
                        legacy image Fitted Luggage
                        Whats not to love?
                        yes the CCR is a great car, and top speed wise you are probably correct, it would be a stretch for the Viper to reach that speed without carefully designed aerodynamics, but for the $250000 price ceiling, the Viper gets my money.
                        if I had unlimited resources I'd get a Bugatti Veyron. Quad turbo W16! 987 SAE HP. Projected top speed (with specially developed tires) 253mph.
                        2002 Subaru Legacy
