  4. Dyno Queen
Dyno Queen
54 Posts 19 Posters 3.0k Views
    that is going to be sweet. how much hp do expect with this setup
    • XJHEADX Offline
      XJHEADX Offline
      XJHEAD
      91nbtsi wrote:
      Looking good man! When do you expect to be ready to run? Pretty exciting.
      I'll be back in town in two weeks, will pick it up from Nick then. As for when ready, hopefully I'll actually have some time to work on it in those two weeks I am in town only have had a few days this last week to work on it.
      Need to pull motor one more time, I have only test fitted everything so far.
      Shooting for about 1,000@20 psi E-85 if the turbos keep up..
      7.64 @ 187 3400 lbs. on KORN
      TTSBF
      RTCTTFMF PTOSITW
        on E-85 gas, thats interesting,
        or did i miss understand you
        • XJHEADX Offline
          XJHEADX Offline
          XJHEAD
          you completely understood, should add 50++ hp probally closer to 100
          TTSBF
          RTCTTFMF PTOSITW
            ^thats awsome, what are you going to use for tuning for it? especailly the e-85, have seprate maps for each fuel?
            • XJHEADX Offline
              XJHEADX Offline
              XJHEAD
              I am running Accel Gen. 7 DFI. I can upload as many tunes as I want...
              TTSBF
              RTCTTFMF PTOSITW
              • StangerBanger96S Offline
                StangerBanger96
                you definitely have to update this thread when it's done getting tuned. I forget to go to TCStangs enough so if you update this one i'll see it actually!
                • XJHEADX Offline
                  XJHEADX Offline
                  XJHEAD
                  Started it up friday night, got just a base tune on it for it to run on its own. Took it for a short test drive sat. Dynotune is picking it up this week, should be ready when I get back in two weeks.. In Arizona again, last time for a couple of months........
                  BTW Nick, twins do not quiet down a V-8 at all:eek: :eek:
                  TTSBF
                  RTCTTFMF PTOSITW
                  • XJHEADX Offline
                    XJHEADX Offline
                    XJHEAD
                    Fuel leaks suck......
                    TTSBF
                    RTCTTFMF PTOSITW
                    • 91nbtsi9 Offline
                      91nbtsi9 Offline
                      91nbtsi
                      Especially when you have a garden hose for a supply line:icon_cyclops:
                      [email protected] -- DSM
                      07 Mega Cab 5.9 CTD
                      • capitljC Offline
                        capitljC Offline
                        capitlj
                        I need more specs on that motor I'm planning a twin setup for the 5.0 on my cat.
                        > Mitch Hedberg wrote:
                        2004 Impala LS 3.8
                          I know that aint a 5.0L
                          • XJHEADX Offline
                            XJHEADX Offline
                            XJHEAD
                            Anyone have an extra washer for 5/8" garden hose, I forgot to put one in:icon_thumleft:
                            Actually is was a cracked fitting, -10 AN to 1/2 pipe thread at one of the rails. Andy at DYNOTUNE found one for me this morning in Watertown and put it on. Hopefully some numbers this week..
                            TTSBF
                            RTCTTFMF PTOSITW
                              thrash
                              Anyone with standalone or at least programmable fuel and forced induction should give E-85 a shot. It works out to about 104 octane, but costs about as much as regular.
                              Additionally, E-85 burns cooler and seems to have some other non-octane related detonation resistance.
                              Boosted cars do especially well on E-85.. you can run significant additional boost and additional spark advance.
                              Note - this is just what I've read. I've got no direct E-85 experience. But given that we are ND/MN residents, where E-85 is most prevalent.. everyone here with forced induction and good fuel control should give it a shot.
                              Other notes - unless you've got at least 30% headroom in your injectors, you'll need bigger ones, as E85 requires more fuel per combustion event (10:1 AFR instead of 14:1 for normal gas)
                              If you learned nothing from this - remember the key take away - E85 is government subsidized 104 octane race gas you can get anywhere in the midwest. 🙂
                              • capitljC Offline
                                capitljC Offline
                                capitlj
                                in my cat of course it is, xjhead's probibly isnt but that doesnt matter im interes in cam lift, duration, overlap, combustion chamber, head flow rate, rocker ratios, and of course HORSEPOWER.
                                2004 Impala LS 3.8
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  XJHEAD
                                  I'm interested in; cam lift, duration, overlap, combustion chamber, head flow rate, rocker ratios, and of course HORSEPOWER.
                                  Lift mid .600's N/A was .714
                                  dur around 230 268
                                  lobe sep. 116* 108
                                  Heads are TFS-R twisted wedge
                                  Intake flow [email protected]??
                                  1.7 rockers
                                  HORSEPOWER TBD
                                  TTSBF
                                  RTCTTFMF PTOSITW
                                  • ruthless351R Offline
                                    ruthless351
                                    Congrats on the ride xj. Cant wait to see it around town. Where did you get your turbo kit? O and just to let everyone know.........i have a 5.0.......no poser here and no cocky son of a @#$%! either. I have to say.......Damn josh i think you pissed them off.
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      XJHEAD
                                      Well I guess this wastegates are too small, Andy had some big time boost creep with it tonight.. Shot up to 17 psi at 5500 rpm pretty quick with 9 lb. springs in it. I guess sunday is out
                                      TTSBF
                                      RTCTTFMF PTOSITW
                                        Deltagates for ya! @ least you dont have their BOV too, cuz it only holds about 10psi.
                                          Overnight some Tial 38mm's.
