  3. ICE and Detailing
  4. Bypassing Safety Feature: In-dash
27 Posts 14 Posters 5.0k Views
  • F Offline
    F Offline
    Fitzy
    Wouldn't really call it advancements considering that the Alpines have been this way for years now.
    2002 Honda S2000
    2006 Dodge Ram CTD
    • treimcheT Offline
      treimcheT Offline
      treimche
      XJHEAD wrote:
      Alpine sucks for this what it needs to see is
      1. 12 volts from footbrake
      2. ground from park brake, ground removed, ground again
      3. 12 volts removed
      I have mine thru toggles (already built into the dash), I will have to look at the E-bay deal to see if that would work, I doubt it though...
      Actually it is much easier to get around Alpine's safety feature than some other brands. I know Pioneer has a certain model or models that you can't do anything to make it play video while driving. With the Alpine, all you have to do is buy this magical little module and hook it up to a few wires. Like I said, I have one that I use every day in my own vehicle, and it works perfectly.
      Troy
      2009 Yamaha R1
      2002 WRX
      2001 Toyota Tundra
      2001 Yamaha R6
      1988 Yamaha YSR 50
      2003 XR50
      • XJHEADX Offline
        XJHEADX Offline
        XJHEAD
        Just looked it up, your right it would work. I couldn't find any time delay relays in 12 volts. This one is a programmable processor, pretty kewl..
        7.64 @ 187 3400 lbs. on KORN
        TTSBF
        RTCTTFMF PTOSITW
        • treimcheT Offline
          treimcheT Offline
          treimche
          The instructions for this thing look ridiculously confusing, until you find the part at the bottom of one of the pages that says "for alpine......." and it tells you exactly what to do, it's awesome.
          Troy
          2009 Yamaha R1
          2002 WRX
          2001 Toyota Tundra
          2001 Yamaha R6
          1988 Yamaha YSR 50
          2003 XR50
          • 99civic9 Offline
            99civic9 Offline
            99civic
            i had to bypass mine to i just hooked it up to a switch instead of the e-break cant remember how i wired it but it worked
            2000 civic SiR - jdm sickness
              yeah but you have a jensen....
                I did the same and I don't own a "Jensen".
                I guess I'm just one of the lucky ones.
