  3. ICE and Detailing
  4. Bypassing Safety Feature: In-dash
27 Posts 14 Posters 5.1k Views
  • 2FNLOUD2
    2FNLOUD2
    2FNLOUD
    there are ways to use a toggle and use it in sequence to make it work. Personally i use a pac TR-7 works everytime have had for year now no problem even after swapping the deck into 3 vehicles. It works on my Alpine Iva-d300 and my Cva 1004.
    • JoelJ
      JoelJ
      switching a toggle a bunch of times u wanted to watch a your screen would just get annoying...
      • G
        G
        green6767
        werd
        08 WRX Hatch
        • 2FNLOUD2
          2FNLOUD2
          2FNLOUD
          then the Pac tr7 is the answer then wires into your remote turn on lead, ground and parking brake. i wired mine in near the brain of the unit and have never touched it since. go for a few bux on ebay usually.
          • treimcheT
            treimcheT
            Do you have the install guide for your Alpine head unit? It will say in there what exactly the head unit needs to see before you can watch movies. You can rig it up with a couple toggle switches like what was said, but 2FNLOUD hit the nail on the head when he said to use the TR-7 module. I currently have one installed in my vehicle with my Alpine head unit and it works like a champ. If you need one of those modules, PM me, they are in stock.
            • XJHEADX
              XJHEADX
              Alpine sucks for this what it needs to see is
              1. 12 volts from footbrake
              2. ground from park brake, ground removed, ground again
              3. 12 volts removed
              I have mine thru toggles (already built into the dash), I will have to look at the E-bay deal to see if that would work, I doubt it though...
              • G
                G
                green6767
                oh wow, I guess advancements have been made in these indash pieces. I guess is not so easy as just tapping into ground for the ebrake.....GOOD LUCK!
                08 WRX Hatch
                • F
                  F
                  Fitzy
                  Wouldn't really call it advancements considering that the Alpines have been this way for years now.
                  2002 Honda S2000
                  2006 Dodge Ram CTD
                  • treimcheT
                    treimcheT
                    3. 12 volts removed
                    Actually it is much easier to get around Alpine's safety feature than some other brands. I know Pioneer has a certain model or models that you can't do anything to make it play video while driving. With the Alpine, all you have to do is buy this magical little module and hook it up to a few wires. Like I said, I have one that I use every day in my own vehicle, and it works perfectly.
                    • XJHEADX
                      XJHEADX
                      Just looked it up, your right it would work. I couldn't find any time delay relays in 12 volts. This one is a programmable processor, pretty kewl..
                      • treimcheT
                        treimcheT
                        The instructions for this thing look ridiculously confusing, until you find the part at the bottom of one of the pages that says "for alpine......." and it tells you exactly what to do, it's awesome.
                        • 99civic9
                          99civic9
                          99civic
                          i had to bypass mine to i just hooked it up to a switch instead of the e-break cant remember how i wired it but it worked
                          2000 civic SiR - jdm sickness
                          • JoelJ
                            JoelJ
                            yeah but you have a jensen....
                            • wesholeW
                              wesholeW
                              I did the same and I don't own a "Jensen".
                              I guess I'm just one of the lucky ones.
