  3. ICE and Detailing
  4. Bypassing Safety Feature: In-dash
27 Posts 14 Posters 5.1k Views
  • MisterCMKM
    MisterCMKM
    it shouldn't with just one click
    thrash;315544 wrote:
    Ford is back :)
    • JoelJ
      JoelJ
      Loosen the cable.. and leave the e-brake pulled half-way! ghetto, but perfect if your like me and have the "git r dun" attitude!
      • JimJ
        JimJ
        there are little boxs's that you hook up that will simulate multiple ebrake clicks and such if they are more advanced decks...
        • JoelJ
          JoelJ
          wannabe wrote:
          I'm sure someone makes a thing you can wire up to break it tho.
          that's what I meant...
          • G
            G
            green6767
            The e-brake is just an output signal, usually negative trigger. Put a test light or multi-meter up to the wire of the e-brake. If I remember right, it will be neutral, then when you pull brake slightly, it will turn to a negative constant pulse. The deck, at least when I had Kenwood indash, it was just an input signal from your ebrake wire, which is just a ground signal. I just put that wire to ground and it was good to go to simulate the ebrake being pulled. Maybe your deck is more advanced, but if the wire diagram just wants you to hook it up to your (-) ebrake wire, then its just an input wire that requires a ground pulse. I could be way off, but I was under the impression that the "clicks" of your ebrake lever was the ratchet type device for the amount of pressure is applied to the ebrake line. The harder you pull, the more pressure is applied to your brakes from the line (cable). Your ebrake is just a contact switch when it comes to the wiring portion of it.
            The only way your deck would know if your car is moving, is if you tapped into the VSS wire or something similar to it, which is usually used for NAV systems. Other than that or a mercury type switch or something, dont know how "smart" their decks are getting, but how else could it tell if your car is moving or not?
            08 WRX Hatch
            • 2FNLOUD2
              2FNLOUD2
              2FNLOUD
              there are ways to use a toggle and use it in sequence to make it work. Personally i use a pac TR-7 works everytime have had for year now no problem even after swapping the deck into 3 vehicles. It works on my Alpine Iva-d300 and my Cva 1004.
              • JoelJ
                JoelJ
                switching a toggle a bunch of times u wanted to watch a your screen would just get annoying...
                • G
                  G
                  green6767
                  werd
                  08 WRX Hatch
                  • 2FNLOUD2
                    2FNLOUD2
                    2FNLOUD
                    then the Pac tr7 is the answer then wires into your remote turn on lead, ground and parking brake. i wired mine in near the brain of the unit and have never touched it since. go for a few bux on ebay usually.
                    • treimcheT
                      treimcheT
                      Do you have the install guide for your Alpine head unit? It will say in there what exactly the head unit needs to see before you can watch movies. You can rig it up with a couple toggle switches like what was said, but 2FNLOUD hit the nail on the head when he said to use the TR-7 module. I currently have one installed in my vehicle with my Alpine head unit and it works like a champ. If you need one of those modules, PM me, they are in stock.
                      • XJHEADX
                        XJHEADX
                        Alpine sucks for this what it needs to see is
                        1. 12 volts from footbrake
                        2. ground from park brake, ground removed, ground again
                        3. 12 volts removed
                        I have mine thru toggles (already built into the dash), I will have to look at the E-bay deal to see if that would work, I doubt it though...
                        • G
                          G
                          green6767
                          oh wow, I guess advancements have been made in these indash pieces. I guess is not so easy as just tapping into ground for the ebrake.....GOOD LUCK!
                          08 WRX Hatch
                          • F
                            F
                            Fitzy
                            Wouldn't really call it advancements considering that the Alpines have been this way for years now.
                            2002 Honda S2000
                            2006 Dodge Ram CTD
                            • treimcheT
                              treimcheT
                              3. 12 volts removed
                              Actually it is much easier to get around Alpine's safety feature than some other brands. I know Pioneer has a certain model or models that you can't do anything to make it play video while driving. With the Alpine, all you have to do is buy this magical little module and hook it up to a few wires. Like I said, I have one that I use every day in my own vehicle, and it works perfectly.
                              • XJHEADX
                                XJHEADX
                                Just looked it up, your right it would work. I couldn't find any time delay relays in 12 volts. This one is a programmable processor, pretty kewl..
                                • treimcheT
                                  treimcheT
                                  The instructions for this thing look ridiculously confusing, until you find the part at the bottom of one of the pages that says "for alpine......." and it tells you exactly what to do, it's awesome.
                                  • 99civic9
                                    99civic9
                                    99civic
                                    i had to bypass mine to i just hooked it up to a switch instead of the e-break cant remember how i wired it but it worked
                                    2000 civic SiR - jdm sickness
                                    • JoelJ
                                      JoelJ
                                      yeah but you have a jensen....
                                      • wesholeW
                                        wesholeW
                                        I did the same and I don't own a "Jensen".
                                        I guess I'm just one of the lucky ones.
