  3. ICE and Detailing
  4. Bypassing Safety Feature: In-dash
27 Posts 14 Posters 4.9k Views
  • G Offline
    G Offline
    green6767
    wannabe wrote:
    switching a toggle a bunch of times u wanted to watch a your screen would just get annoying...
    werd
    08 WRX Hatch
    • 2FNLOUD2 Offline
      2FNLOUD2 Offline
      2FNLOUD
      then the Pac tr7 is the answer then wires into your remote turn on lead, ground and parking brake. i wired mine in near the brain of the unit and have never touched it since. go for a few bux on ebay usually.
        Do you have the install guide for your Alpine head unit? It will say in there what exactly the head unit needs to see before you can watch movies. You can rig it up with a couple toggle switches like what was said, but 2FNLOUD hit the nail on the head when he said to use the TR-7 module. I currently have one installed in my vehicle with my Alpine head unit and it works like a champ. If you need one of those modules, PM me, they are in stock.
        • XJHEADX Offline
          XJHEADX Offline
          Alpine sucks for this what it needs to see is
          1. 12 volts from footbrake
          2. ground from park brake, ground removed, ground again
          3. 12 volts removed
          I have mine thru toggles (already built into the dash), I will have to look at the E-bay deal to see if that would work, I doubt it though...
          • G Offline
            G Offline
            green6767
            oh wow, I guess advancements have been made in these indash pieces. I guess is not so easy as just tapping into ground for the ebrake.....GOOD LUCK!
            08 WRX Hatch
            • F Offline
              F Offline
              Fitzy
              Wouldn't really call it advancements considering that the Alpines have been this way for years now.
              2002 Honda S2000
              2006 Dodge Ram CTD
                3. 12 volts removed
                Actually it is much easier to get around Alpine's safety feature than some other brands. I know Pioneer has a certain model or models that you can't do anything to make it play video while driving. With the Alpine, all you have to do is buy this magical little module and hook it up to a few wires. Like I said, I have one that I use every day in my own vehicle, and it works perfectly.
                • XJHEADX Offline
                  XJHEADX Offline
                  Just looked it up, your right it would work. I couldn't find any time delay relays in 12 volts. This one is a programmable processor, pretty kewl..
                    The instructions for this thing look ridiculously confusing, until you find the part at the bottom of one of the pages that says "for alpine......." and it tells you exactly what to do, it's awesome.
                    • 99civic9 Offline
                      99civic9 Offline
                      99civic
                      i had to bypass mine to i just hooked it up to a switch instead of the e-break cant remember how i wired it but it worked
                      2000 civic SiR - jdm sickness
                        yeah but you have a jensen....
                          I did the same and I don't own a "Jensen".
                          I guess I'm just one of the lucky ones.
