  4. Dyno in Fargo May 12 & 13
24 Posts 12 Posters 1.0k Views
  • D Offline
    D Offline
    dynotune
    We'll be at straightline specialties on May 12 & 13 (I believe it's fri/ sat) Please call for an appointment if at all possible, as we have quite a few already lined up. We can make pulls or do tuning, I just need to know what we're doing and how much time to spend. LS1 edit, Ford chips, and all other programming available. Give me a call or email- I don't check back to forums as often as I should...
    andy
    (605) 753-1101
    [email protected]
    DynoTune Speed & Performance
    Mobile chassis dyno service
    www.dynotuneusa.com
    (605) 753-1101
      pm'd about the honduh
        i will call tomarrow about ether my s2000 or my crx to get tuned.
          Who is going to be dynoing this Fri and Sat? I think Raider is, who else?
            I am on saturday. showin up at around noon...car is supposed to get tuned @ around 1
              any word on some numbers from you guys
              • camzaro28C Offline
                camzaro28C Offline
                camzaro28
                well torbs was there. he put down less then he was expecting. i think 4 cars have went the last 5 hours, pretty slow going
                jig 4 prez
                • 9 Offline
                  9 Offline
                  97lt1
                  290/308 is what I put down. Once I get it tuned for the cam and throw on my CAI I should get atleast 310 hp out of it.
                  Brian are you putting the dyno videos on the net?
                    camzaro28C Offline
                    camzaro28
                    once i get around to it. got to figure soemthing out first
                    jig 4 prez
                      My s2000 put down 200 hp and 137 ft/lbs of torque. I was pretty happy with the numbers being it's stock with an intake.
                        Damn that's really good matt. what's the stock rating one one??
                          like 240 flywheel hp i think isnt it? that actually is a big drop because its through a manual...hmmm
                            What s2000 have you seen put down more with a cai. That is pretty good for an ap1 s2000(2.0L). So i think it is a pretty strong motor.
                              I wasn't saying I've seen an S2000 motor put down more with just a CAI, I was simply commenting that it lost 1/6th of its crank power to the wheels. I guess I just expected a little more maybe?
                              I guess it's roughly 17% loss which isn't horrible but maybe it seems worse than it is...idk
                              • RaiderR Offline
                                RaiderR Offline
                                Raider
                                I dynoed Friday but with shitty results...my damn speed limiter is still turned on(im pissed at my tuner) an the truck shut down at 105 mph@4200 rpm's....I did have 340hp at that mark...there should be 30+hp it in on a full run
                                POWERD BY
                                  couldnt andy tune that out for you?
                                  • RaiderR Offline
                                    RaiderR Offline
                                    Raider
                                    I run SCT software and he has Daiblo
                                    POWERD BY
                                      understatement of the year...i gata figure out what's going on...put down stock power (113whp)...with 10.8:1 compression, zex 59300 stg. 2 cam, full race header, and ITBs...and that was on the stock ECU, couldnt get crome to work @ all...not a very good day to say the least...I don't get it though, unless the ITBs are really fucking something up, vtec isnt working right, or my motor is just getting weak (which could be the case, it was smoking a bit at the beginning, but by the 3rd run it wasnt smoking anymore)...time to do a comp. test. Anybody got a y8 vtec solonoid I could borrow for like 1/2 hr. just to check and see if mine is working correctly? thanks
                                      • Spec_RS Offline
                                        Spec_RS Offline
                                        Spec_R
                                        That's horrible...
                                        F20C I4 engine producing 240 hp at 8300 rpm and 153 ft-lb torque at 7500 rpm from factory. Don't you own a S2000? You should've known that.
                                        The reason why people modified their cars is to increase horsepower...if whatever you said is true...you lost 40 hp and 16 ft-lb of torque...?
                                          Spec_R wrote:
                                          That's horrible...
                                          honestly tho, its really only like 17% drivetrain loss which isnt horrible...it seems worse than it really is
