Dyno in Fargo May 12 & 13
i will call tomarrow about ether my s2000 or my crx to get tuned.
My s2000 put down 200 hp and 137 ft/lbs of torque. I was pretty happy with the numbers being it's stock with an intake.
DrifterExtreme wrote:
My s2000 put down 200 hp and 137 ft/lbs of torque. I was pretty happy with the numbers being it's stock with an intake.Damn that's really good matt. what's the stock rating one one??
PSiedTSi wrote:
like 240 flywheel hp i think isnt it? that actually is a big drop because its through a manual...hmmmWhat s2000 have you seen put down more with a cai. That is pretty good for an ap1 s2000(2.0L). So i think it is a pretty strong motor.
What s2000 have you seen put down more with a cai. That is pretty good for an ap1 s2000(2.0L). So i think it is a pretty strong motor.I wasn't saying I've seen an S2000 motor put down more with just a CAI, I was simply commenting that it lost 1/6th of its crank power to the wheels. I guess I just expected a little more maybe?
I guess it's roughly 17% loss which isn't horrible but maybe it seems worse than it is...idk
camzaro28 wrote:
well torbs was there. he put down less then he was expecting.understatement of the year...i gata figure out what's going on...put down stock power (113whp)...with 10.8:1 compression, zex 59300 stg. 2 cam, full race header, and ITBs...and that was on the stock ECU, couldnt get crome to work @ all...not a very good day to say the least...I don't get it though, unless the ITBs are really fucking something up, vtec isnt working right, or my motor is just getting weak (which could be the case, it was smoking a bit at the beginning, but by the 3rd run it wasnt smoking anymore)...time to do a comp. test. Anybody got a y8 vtec solonoid I could borrow for like 1/2 hr. just to check and see if mine is working correctly? thanks
My s2000 put down 200 hp and 137 ft/lbs of torque. I was pretty happy with the numbers being it's stock with an intake.That's horrible...
F20C I4 engine producing 240 hp at 8300 rpm and 153 ft-lb torque at 7500 rpm from factory. Don't you own a S2000? You should've known that.
The reason why people modified their cars is to increase horsepower...if whatever you said is true...you lost 40 hp and 16 ft-lb of torque...? -
Spec_R wrote:
That's horrible...
The reason why people modified their cars is to increase horsepower...if whatever you said is true...you lost 40 hp and 16 ft-lb of torque...?honestly tho, its really only like 17% drivetrain loss which isnt horrible...it seems worse than it really is
Spec_R wrote:
That's horrible...
The reason why people modified their cars is to increase horsepower...if whatever you said is true...you lost 40 hp and 16 ft-lb of torque...?Are you serious?.....240/153 are at the FLYWHEEL, while my 200/137 is at the WHEELS. so there not that bad concidering the loss throgh the drivetrain.
