  4. Dyno in Fargo May 12 & 13
24 Posts 12 Posters 1.6k Views
  • King RicerK
    King RicerK
    DrifterExtreme wrote:
    My s2000 put down 200 hp and 137 ft/lbs of torque. I was pretty happy with the numbers being it's stock with an intake.
    Damn that's really good matt. what's the stock rating one one??
    Trafik Jamz;299122 wrote:
    • PSiedTSiP
      PSiedTSiP
      like 240 flywheel hp i think isnt it? that actually is a big drop because its through a manual...hmmm
      spanish-rice;237125 wrote:
      • DrifterExtremeD
        DrifterExtremeD
        What s2000 have you seen put down more with a cai. That is pretty good for an ap1 s2000(2.0L). So i think it is a pretty strong motor.
        • PSiedTSiP
          PSiedTSiP
          I wasn't saying I've seen an S2000 motor put down more with just a CAI, I was simply commenting that it lost 1/6th of its crank power to the wheels. I guess I just expected a little more maybe?
          I guess it's roughly 17% loss which isn't horrible but maybe it seems worse than it is...idk
          • RaiderR
            RaiderR
            Raider
            I dynoed Friday but with shitty results...my damn speed limiter is still turned on(im pissed at my tuner) an the truck shut down at 105 mph@4200 rpm's....I did have 340hp at that mark...there should be 30+hp it in on a full run
            POWERD BY
            • PSiedTSiP
              PSiedTSiP
              couldnt andy tune that out for you?
              • RaiderR
                RaiderR
                Raider
                I run SCT software and he has Daiblo
                POWERD BY
                • torbsT
                  torbsT
                  camzaro28 wrote:
                  well torbs was there. he put down less then he was expecting.
                  understatement of the year...i gata figure out what's going on...put down stock power (113whp)...with 10.8:1 compression, zex 59300 stg. 2 cam, full race header, and ITBs...and that was on the stock ECU, couldnt get crome to work @ all...not a very good day to say the least...I don't get it though, unless the ITBs are really fucking something up, vtec isnt working right, or my motor is just getting weak (which could be the case, it was smoking a bit at the beginning, but by the 3rd run it wasnt smoking anymore)...time to do a comp. test. Anybody got a y8 vtec solonoid I could borrow for like 1/2 hr. just to check and see if mine is working correctly? thanks
                  • Spec_RS
                    Spec_RS
                    Spec_R
                    That's horrible...
                    F20C I4 engine producing 240 hp at 8300 rpm and 153 ft-lb torque at 7500 rpm from factory. Don't you own a S2000? You should've known that.
                    The reason why people modified their cars is to increase horsepower...if whatever you said is true...you lost 40 hp and 16 ft-lb of torque...?
                    • PSiedTSiP
                      PSiedTSiP
                      Spec_R wrote:
                      That's horrible...
                      honestly tho, its really only like 17% drivetrain loss which isnt horrible...it seems worse than it really is
                      • DrifterExtremeD
                        DrifterExtremeD
                        Spec_R wrote:
                        That's horrible...
                        Are you serious?.....240/153 are at the FLYWHEEL, while my 200/137 is at the WHEELS. so there not that bad concidering the loss throgh the drivetrain.
                        • HandoEXH
                          HandoEXH
                          Spec_R wrote:
                          That's horrible...
                          Ahahaha, ummmm....PWN3D yourself!
                          • Spec_RS
                            Spec_RS
                            Spec_R
                            sorry i read your post wrong...my bad
                            • torbsT
                              torbsT
                              Spec_R wrote:
                              That's horrible...
                              we are talking whp, not bhp...
