  4. Governor
Governor
30 Posts 11 Posters 1.9k Views
  • LoveMachine69L Offline
    LoveMachine69
    Does anyone know how much it would be to remove or reflash a governor?
    2001 grand prix
    1982 S-10
    2001 cr-125 for sale $2000 or best offer
      on what vehicle?
        LoveMachine69
        a 2001 Grand Prix GT
        2001 grand prix
        1982 S-10
          Get a DHP PCM. They are about $250 I believe.
            i believe the jet chip for that application well do it also
              LoveMachine69
              Im just not sure how to do any of that stuff but it sucks when my car tops out at 107
              2001 grand prix
              1982 S-10
                DO NOT WASTE YOUR MONEY ON A JET CHIP!
                You can't do it yourself, you need to get a reflashed ECU from DHP like I said.
                http://www.pfyc.com/store/merchant.mv?Screen=PROD&Store_Code=PFYC&Product_Code=GP3012&Product_Count=0&Category_Code=GPUNDER
                Seems its only $99 now.
                  find someplace online that has roms for your car and I can (maybe) reflash your ecu for you.
                    LoveMachine69
                    Im probably going to buy than PCM thanks for your help PSiedTSI
                    2001 grand prix
                    1982 S-10
                    • Turbo5OhT Offline
                      Turbo5OhT Offline
                      Turbo5Oh
                      just dont go over 107 and dont die....its simple
                        LoveMachine69
                        i just want to see how fast my car can go without the governor
                        2001 grand prix
                        1982 S-10
                        • JoKeRJ Offline
                          JoKeRJ Offline
                          JoKeR
                          a lot faster but is it really worth it????
                          :icon_jokercolor:
                          Black 99 z28
                            LoveMachine69
                            as long as i dont get caught
                            2001 grand prix
                            1982 S-10
                              The PCM does more than just remove the speed limiter.
                                LoveMachine69
                                it raises the rev limiter to but what else does it do?
                                2001 grand prix
                                1982 S-10
                                  LoveMachine69
                                  Doesn't anyone else ever just want to top out there car out of curiosity to see how fast it will go
                                  2001 grand prix
                                  1982 S-10
                                    Speed limiter removed
                                    3-1 and 4-2 skip shifts
                                    Transmission line pressure increased
                                    Shift points moved to 5800-6000 RPM
                                    Fan turn on points altered as follows:
                                    186 degree F turn on
                                    2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
                                    MAF calibration adjusted for proper year
                                    Fuel/spark adjustments as follows:
                                    Enrichens fuel delivery for critical problem areas
                                    Provides a consistent power gain across the entire power band
                                    Reduces spark retard (knock retard)
                                    Removes "40MPH wide open throttle lag" experienced with your stock PCM
                                    For most GP guys this is the most worthwhile mod they do. It usually gives around 12whp difference. Not bad for a stock NA car.
                                      LoveMachine69
                                      For $100 i think thats a good deal
                                      2001 grand prix
                                      1982 S-10
                                        ya, but dont go posting about it. at 117 in a grand prix is pretty fast, unless they rased it for the newerones
                                          LoveMachine69
                                          i know the 2004 and up is higher and mines only 107 not 117
                                          2001 grand prix
                                          1982 S-10
