  4. external wastgate
external wastgate
22 Posts 10 Posters 908 Views
  • GnArKiLlG Offline
    GnArKiLlG Offline
    GnArKiLl
    ok how do i hook my external wastgate up i have the tial 38mm what do the 2 air fittings go to (i was thinkin boost controler?) and the flange on the wastgate that doesnt bolt to the manifold does that just act as in external dump?
    1976 Chevy K5- lifted beater
      You don't actually need a wastegate. Its all a marketing ploy..... 😄
      • GreenLanternG Offline
        GreenLantern
        the second flange on the wastegate is an atmospheric dump....the top vaccuum port is left open and the side port is tapped into the intake manifold at a vaccuum source
        i have pictures of the one on my GSR if you need pics for a reference
        • GnArKiLlG Offline
          GnArKiLlG Offline
          GnArKiLl
          yea let me check it out
          • GnArKiLlG Offline
            GnArKiLlG Offline
            GnArKiLl
            ok and how then do i hook up my boost controler?
              it goes on the line between the intake manifold and wastegate to control the pressure that the wastegate sees.
              • GnArKiLlG Offline
                GnArKiLlG Offline
                GnArKiLl
                ok just so u guys know this is goin on a 1g dsm
                • GnArKiLlG Offline
                  GnArKiLlG Offline
                  GnArKiLl
                  still dont get it i have the install guide from tial and it made it even harder to get
                    The vacuum port on the top of it is hooked up to your boost controller, which in turn is hooked up to a source of boost/vacuum(Intake manifold, compressor housing, etc)...
                    • GnArKiLlG Offline
                      GnArKiLlG Offline
                      GnArKiLl
                      ok and the side one goes where?
                        What side? The actual flanged part? The part we are staring at is the Dump side...
                        • GnArKiLlG Offline
                          GnArKiLlG Offline
                          GnArKiLl
                          there is a port on the back side too..
                            OK, I'm confused what you are asking I guess. There are the 2 flanges one is for inlet, one is for dump...
                            • GnArKiLlG Offline
                              GnArKiLlG Offline
                              GnArKiLl
                              yea and there are 2 ports for air one on the very top and one the back side by the exhaust inlet
                                ha i hope your not talking about the side that goes on the exhaust mani..
                                • GnArKiLlG Offline
                                  GnArKiLlG Offline
                                  GnArKiLl
                                  [QUOTE=PSiedTSi]legacy image
                                  no i know what the exhaust flange's are for but the vac port on the very top there is another on the back side of the wasegate
                                    Ok, NM I know what he's saying...the side port one is connected to like the compressor housing or some source BEFORE the throttle plate, and the top one is for a boost controller...
                                    • GnArKiLlG Offline
                                      GnArKiLlG Offline
                                      GnArKiLl
                                      ok so i need to drill and tap a hole in my compressor housing and put a fitting in it right?
                                        NO. Leave the top one alone. Put your boost controller inline with the side vacuum port on the wastegate.
                                          i will second that...
