  4. external wastgate
external wastgate
22 Posts 10 Posters 1.1k Views
  • GnArKiLlG Offline
    GnArKiLlG Offline
    GnArKiLl
    ok and how then do i hook up my boost controler?
    1976 Chevy K5- lifted beater
      it goes on the line between the intake manifold and wastegate to control the pressure that the wastegate sees.
      • GnArKiLlG Offline
        GnArKiLlG Offline
        GnArKiLl
        ok just so u guys know this is goin on a 1g dsm
        • GnArKiLlG Offline
          GnArKiLlG Offline
          GnArKiLl
          still dont get it i have the install guide from tial and it made it even harder to get
            The vacuum port on the top of it is hooked up to your boost controller, which in turn is hooked up to a source of boost/vacuum(Intake manifold, compressor housing, etc)...
            • GnArKiLlG Offline
              GnArKiLlG Offline
              GnArKiLl
              ok and the side one goes where?
                What side? The actual flanged part? The part we are staring at is the Dump side...
                • GnArKiLlG Offline
                  GnArKiLlG Offline
                  GnArKiLl
                  there is a port on the back side too..
                    OK, I'm confused what you are asking I guess. There are the 2 flanges one is for inlet, one is for dump...
                    • GnArKiLlG Offline
                      GnArKiLlG Offline
                      GnArKiLl
                      yea and there are 2 ports for air one on the very top and one the back side by the exhaust inlet
                        ha i hope your not talking about the side that goes on the exhaust mani..
                        • GnArKiLlG Offline
                          GnArKiLlG Offline
                          GnArKiLl
                          [QUOTE=PSiedTSi]legacy image
                          no i know what the exhaust flange's are for but the vac port on the very top there is another on the back side of the wasegate
                            Ok, NM I know what he's saying...the side port one is connected to like the compressor housing or some source BEFORE the throttle plate, and the top one is for a boost controller...
                            • GnArKiLlG Offline
                              GnArKiLlG Offline
                              GnArKiLl
                              ok so i need to drill and tap a hole in my compressor housing and put a fitting in it right?
                                NO. Leave the top one alone. Put your boost controller inline with the side vacuum port on the wastegate.
                                  i will second that...
                                  • XJHEADX Offline
                                    XJHEADX Offline
                                    If you don't know the fucking answer DON'T ANSWER and I wondered why everyones shit gets fucked up around here....
                                    • Sweet-WRX-LovinS Offline
                                      Sweet-WRX-Lovin
                                      Bad day?
                                      One time...
