  4. external wastgate
external wastgate
22 Posts 10 Posters 779 Views
    You don't actually need a wastegate. Its all a marketing ploy..... 😄
    • GreenLanternG Offline
      GreenLantern
      the second flange on the wastegate is an atmospheric dump....the top vaccuum port is left open and the side port is tapped into the intake manifold at a vaccuum source
      i have pictures of the one on my GSR if you need pics for a reference
      • GnArKiLlG Offline
        GnArKiLlG Offline
        GnArKiLl
        yea let me check it out
        1976 Chevy K5- lifted beater
        • GnArKiLlG Offline
          GnArKiLlG Offline
          GnArKiLl
          ok and how then do i hook up my boost controler?
            it goes on the line between the intake manifold and wastegate to control the pressure that the wastegate sees.
            • GnArKiLlG Offline
              GnArKiLlG Offline
              GnArKiLl
              ok just so u guys know this is goin on a 1g dsm
              • GnArKiLlG Offline
                GnArKiLlG Offline
                GnArKiLl
                still dont get it i have the install guide from tial and it made it even harder to get
                  The vacuum port on the top of it is hooked up to your boost controller, which in turn is hooked up to a source of boost/vacuum(Intake manifold, compressor housing, etc)...
                  • GnArKiLlG Offline
                    GnArKiLlG Offline
                    GnArKiLl
                    ok and the side one goes where?
                      What side? The actual flanged part? The part we are staring at is the Dump side...
                      • GnArKiLlG Offline
                        GnArKiLlG Offline
                        GnArKiLl
                        there is a port on the back side too..
                          OK, I'm confused what you are asking I guess. There are the 2 flanges one is for inlet, one is for dump...
                          • GnArKiLlG Offline
                            GnArKiLlG Offline
                            GnArKiLl
                            yea and there are 2 ports for air one on the very top and one the back side by the exhaust inlet
                              ha i hope your not talking about the side that goes on the exhaust mani..
                              • GnArKiLlG Offline
                                GnArKiLlG Offline
                                GnArKiLl
                                [QUOTE=PSiedTSi]legacy image
                                no i know what the exhaust flange's are for but the vac port on the very top there is another on the back side of the wasegate
                                  Ok, NM I know what he's saying...the side port one is connected to like the compressor housing or some source BEFORE the throttle plate, and the top one is for a boost controller...
                                  • GnArKiLlG Offline
                                    GnArKiLlG Offline
                                    GnArKiLl
                                    ok so i need to drill and tap a hole in my compressor housing and put a fitting in it right?
                                      NO. Leave the top one alone. Put your boost controller inline with the side vacuum port on the wastegate.
                                        i will second that...
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          If you don't know the fucking answer DON'T ANSWER and I wondered why everyones shit gets fucked up around here....
