  4. external wastgate
external wastgate
22 Posts 10 Posters 779 Views
    GnArKiLl wrote:
    ok and the side one goes where?
    What side? The actual flanged part? The part we are staring at is the Dump side...
    • GnArKiLlG Offline
      GnArKiLlG Offline
      GnArKiLl
      there is a port on the back side too..
      1976 Chevy K5- lifted beater
        OK, I'm confused what you are asking I guess. There are the 2 flanges one is for inlet, one is for dump...
        • GnArKiLlG Offline
          GnArKiLlG Offline
          GnArKiLl
          yea and there are 2 ports for air one on the very top and one the back side by the exhaust inlet
            ha i hope your not talking about the side that goes on the exhaust mani..
            • GnArKiLlG Offline
              GnArKiLlG Offline
              GnArKiLl
              [QUOTE=PSiedTSi]legacy image
              no i know what the exhaust flange's are for but the vac port on the very top there is another on the back side of the wasegate
                Ok, NM I know what he's saying...the side port one is connected to like the compressor housing or some source BEFORE the throttle plate, and the top one is for a boost controller...
                • GnArKiLlG Offline
                  GnArKiLlG Offline
                  GnArKiLl
                  ok so i need to drill and tap a hole in my compressor housing and put a fitting in it right?
                    NO. Leave the top one alone. Put your boost controller inline with the side vacuum port on the wastegate.
                      i will second that...
                      • XJHEADX Offline
                        XJHEADX Offline
                        If you don't know the fucking answer DON'T ANSWER and I wondered why everyones shit gets fucked up around here....
                        • Sweet-WRX-LovinS Offline
                          Sweet-WRX-Lovin
                          Bad day?
                          One time...
