  4. Ignition upgrade????
21 Posts 8 Posters 1.2k Views
  • ruthless351R Offline
    ruthless351
    Ha ! On a stock engine that has hyperutectic pistons.......... i dont think so. Ive heard alot of stories bout that stuff. I dont know if its true bout pistons failing but i dont want to find out with my engine. Besides i dont have any fuel adjustment ie. pressures
      A wet nitrous kit will take care of everything. You'll be fine w/ the pistons...
        slowvo
        No kidding, havent you seen the fast and the furious, thompson?!?
          ruthless351
          HaHa yeah........I dont really want to go in the nitrous direction. Maybe a cam wil fit the bill.
          • XJHEADX Offline
            XJHEADX Offline
            ruthless351 wrote:
            I made $300 what else could i put in towards? Im already getting tires and lowering springs this spring.
            What are the long term goals??? Start there so you do not make repeat purchases or make unnecessary puchases.
              ruthless351
              Well i dont want a car that i cant drive during the summer due to aggressive cam profile or anything like that. My goal is to build the HP to or about 400 maybe even 375. So maybe a cam is a better idea. Then the heads,intake and then either a s/c or turbo can come later.
              • D Offline
                D Offline
                dynotune
                buy a trick flow intake $375 or so (track heat) a throttle body, exhaust, some hard parts.... the stock TFI does a good job for quite a while
                DynoTune Speed & Performance
                Mobile chassis dyno service
                www.dynotuneusa.com
                (605) 753-1101
                  ruthless351
                  I got longtubes and matching h-pipe w/ dynomax cat-back for my exhaust and a CAI for intake. That bout sums it up for hard parts. I like that SSI intake from BBK. Besides it comes with TB for little extra cash.
                    As long as you don't go lean the hyper pistons in those cars will take a lot of abuse. If you do decide to go with nitrous, which I would definately recommend, get a dry kit. With wet kits, the fuel likes to pool in the upper intake and backfire.
                      ruthless351
                      That wouldnt be too good now would it!!!!!!!!!!
                        nah, not really. 😄
                        A nitrous kit will run you $600 when its all said and done. Pretty easy. I'd even help ya put it in.
