  4. Ignition upgrade????
21 Posts 8 Posters 1.3k Views
  • DanglerD Offline
    DanglerD Offline
    Dangler
    just avoid anything "AEM" relative to ignition 😄
    • ruthless351R Offline
      ruthless351
      dynotune wrote:
      what is your set-up right now... it depends- if you still run a TFI and N/A you won't see much of a gain, spark energy is more consistent above 5500-6000 (not sure if you are making power up there or not...) It's not bad money spent, but don't look for it to work miracles, that's all.
      andy
      My set-up is stock with no power adders. I got some extra money from doing a headgasket job for someone and wanna up grade the ignition sysstem. Not lookin for any miracles just lookin to upgrade.
      • XJHEADX Offline
        XJHEADX Offline
        Spend the $ on something else..
          ruthless351
          I made $300 what else could i put in towards? Im already getting tires and lowering springs this spring.
            Nitrous kit...
              ruthless351
              Ha ! On a stock engine that has hyperutectic pistons.......... i dont think so. Ive heard alot of stories bout that stuff. I dont know if its true bout pistons failing but i dont want to find out with my engine. Besides i dont have any fuel adjustment ie. pressures
                A wet nitrous kit will take care of everything. You'll be fine w/ the pistons...
                  slowvo
                  No kidding, havent you seen the fast and the furious, thompson?!?
                    ruthless351
                    HaHa yeah........I dont really want to go in the nitrous direction. Maybe a cam wil fit the bill.
                    • XJHEADX Offline
                      XJHEADX Offline
                      What are the long term goals??? Start there so you do not make repeat purchases or make unnecessary puchases.
                        ruthless351
                        Well i dont want a car that i cant drive during the summer due to aggressive cam profile or anything like that. My goal is to build the HP to or about 400 maybe even 375. So maybe a cam is a better idea. Then the heads,intake and then either a s/c or turbo can come later.
                        • D Offline
                          D Offline
                          dynotune
                          buy a trick flow intake $375 or so (track heat) a throttle body, exhaust, some hard parts.... the stock TFI does a good job for quite a while
                          DynoTune Speed & Performance
                          Mobile chassis dyno service
                          www.dynotuneusa.com
                          (605) 753-1101
                            ruthless351
                            I got longtubes and matching h-pipe w/ dynomax cat-back for my exhaust and a CAI for intake. That bout sums it up for hard parts. I like that SSI intake from BBK. Besides it comes with TB for little extra cash.
                              As long as you don't go lean the hyper pistons in those cars will take a lot of abuse. If you do decide to go with nitrous, which I would definately recommend, get a dry kit. With wet kits, the fuel likes to pool in the upper intake and backfire.
                                ruthless351
                                That wouldnt be too good now would it!!!!!!!!!!
                                  nah, not really. 😄
                                  A nitrous kit will run you $600 when its all said and done. Pretty easy. I'd even help ya put it in.
