  4. Ignition upgrade????
21 Posts 8 Posters 1.3k Views
  • ruthless351R Offline
    ruthless351
    Hey everyone.....i want to order the Accel 300+ ignition kit from jegs for the stang and just wondering if its worth the $240. It comes with the module and a coil and some wiring. Just lookin for some imput......thanks everyone.
      Anytime you can increase spark energy, it's a good thing. you will definately notice the improvement if you had a boosted application. But, even in an n/a app. it's a good investment.
      This should be in the tech section.
        ruthless351
        Your right.......sorry i wasnt thinkin when i posted it. Thanks for the advise anywayz
        • D Offline
          D Offline
          dynotune
          what is your set-up right now... it depends- if you still run a TFI and N/A you won't see much of a gain, spark energy is more consistent above 5500-6000 (not sure if you are making power up there or not...) It's not bad money spent, but don't look for it to work miracles, that's all.
          andy
          DynoTune Speed & Performance
          Mobile chassis dyno service
          www.dynotuneusa.com
          (605) 753-1101
            I would go with the Mallory 685. It has a 2 stage rev limiter along with an RPM activated window switch and timing retard. The box is $240 from Summit. We put this into Brian's (Camzaro28) car and it was really easy to use and set up. Also get the adapter harness from MSD or whoever makes the harness to plug and play. As far as a coil I would get the Accel or MSD from summit as well. I ordered up the Accel when I did plugs and wires and its been fine for me. Also might want to pick up some FRPP (Ford Racing Performance Parts) 9mm plug wires which are around $40 along with a new cap and rotor.
            • DanglerD Offline
              DanglerD Offline
              Dangler
              just avoid anything "AEM" relative to ignition 😄
                ruthless351
                andy
                My set-up is stock with no power adders. I got some extra money from doing a headgasket job for someone and wanna up grade the ignition sysstem. Not lookin for any miracles just lookin to upgrade.
                • XJHEADX Offline
                  XJHEADX Offline
                  Spend the $ on something else..
                    ruthless351
                    I made $300 what else could i put in towards? Im already getting tires and lowering springs this spring.
                      Nitrous kit...
                        ruthless351
                        Ha ! On a stock engine that has hyperutectic pistons.......... i dont think so. Ive heard alot of stories bout that stuff. I dont know if its true bout pistons failing but i dont want to find out with my engine. Besides i dont have any fuel adjustment ie. pressures
                          A wet nitrous kit will take care of everything. You'll be fine w/ the pistons...
                            slowvo
                            No kidding, havent you seen the fast and the furious, thompson?!?
                              ruthless351
                              HaHa yeah........I dont really want to go in the nitrous direction. Maybe a cam wil fit the bill.
                              • XJHEADX Offline
                                XJHEADX Offline
                                What are the long term goals??? Start there so you do not make repeat purchases or make unnecessary puchases.
                                  ruthless351
                                  Well i dont want a car that i cant drive during the summer due to aggressive cam profile or anything like that. My goal is to build the HP to or about 400 maybe even 375. So maybe a cam is a better idea. Then the heads,intake and then either a s/c or turbo can come later.
                                  • D Offline
                                    D Offline
                                    dynotune
                                    buy a trick flow intake $375 or so (track heat) a throttle body, exhaust, some hard parts.... the stock TFI does a good job for quite a while
                                    www.dynotuneusa.com
                                    (605) 753-1101
                                      ruthless351
                                      I got longtubes and matching h-pipe w/ dynomax cat-back for my exhaust and a CAI for intake. That bout sums it up for hard parts. I like that SSI intake from BBK. Besides it comes with TB for little extra cash.
                                        As long as you don't go lean the hyper pistons in those cars will take a lot of abuse. If you do decide to go with nitrous, which I would definately recommend, get a dry kit. With wet kits, the fuel likes to pool in the upper intake and backfire.
                                          ruthless351
                                          That wouldnt be too good now would it!!!!!!!!!!
