  4. cavi electrical demon
12 Posts 7 Posters 943 Views
    I did that once and it blew the main fuse under the hood(on mine at least), it may have done the same but not burned quite all the way through, fuses can do that from time to time. When in doubt, check the fuses first.
      Unlike most import vehicles, Gm doesn't have a "main" fuse per say. Nor does it have an alternator fuse. It may be the battery. Do this, jump start it and disconnect the negative terminal. If it dies, replace your alternator. If not, replace the battery.
        I'd check your main grounding points to see if any are loose/corroded
          Bah! Diggin too far into it. I'll lay $ on the alternator.
            If the alternator tests good check your ground cable conections and clean them up and make sure all your battery cables are in good shape an there's no corrosion everywhere...I had a prelude one time that had a new alternator in it, turns out it was just the ground cable was corroded where it connects to the frame...
            • lord_deastofactL Offline
              lord_deastofact
              k, good to hear your thoughts on it, most of you are thinking about the same as me, I wanted to get some opinions before I really looked at it, to see if I can save him some money.
              Minute ricer!
              • Cura86C Offline
                Cura86C Offline
                Cura86
                Maybe the Voltage Reg????
                www.RoadsideSalvage.com
                  Which is IN the alternator.
                    lord_deastofact
                    turned out to just be a bad wire. he took it to a shop before I could look at it. thanks guys!
                    Minute ricer!
                    • ticklemedalyT Offline
                      ticklemedaly
                      just guessing the fusible link on the power wire to the starter from the altenator? thats where I would have started.
                      XBL G-tag: TickleMeDaly83
