  4. My L67 3800 Swap
My L67 3800 Swap
13 Posts 9 Posters 1.7k Views
  • wa2fastcamaroW Offline
    wa2fastcamaro
    Most of you guys probably won't care about this swap, but I swapped a series 2 supercharged motor and tranny into my series 1 93 Bonneville.
    This is what I have been doing for the part few weeks.
    Started with this, 1993 Bonneville SSE
    Had a series 1 supercharged 3800 with 190K on it
    Baught a 97 SSEI wrecked with a series 2 supercharger 3800 with only 67K on it.
    pulled the motor and swapped it in my old bonne
    New motor in car and running great
    Nothing too fancy, but it was a hell of a challenge making everyhting work, as it was a obd1 car and now is obd2.
    Faster than hell now too, last a lot more power than it used to. Planning custom exhaust for it soon and have a intercooler for the supercharger on order.
    Mike
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
    • kylushK Offline
      kylushK Offline
      kylush
      Cool swap dude! I was thinking about swapping one of those motors and trans into my old 91 lumina with the 3.1 before I sold it... Saw one guy that did it and it was really cool
      1998 Z28 Camaro
        How hard would something like that be to do to a 91 regal with a 3.8 tuned port engine in it at the moment...
          wa2fastcamaro
          couldn't tell you, I swapped the whole cradle since them were the same, if the motor and tranny bolt up the same then getting it in the car is easy. They you just got to plumb fuel lines and make a wiring harness.
          Mike
          Phone: 701-371-5615
            Nice work.....so what all did you use out of the donor car and what stayed with the car?? How is the tranny that you pulled (i mite be interested in it)
              Mike
              Ok, cause far as i know it's just basically a series one that's not supercharged...
                wa2fastcamaro
                well the donor car is pretty much gutted as I upgraded most of my 93 to 97 parts, nicer interior, bose radio system, etc...
                Tranny shifted great, but has a bad output shaft bearing. If you replaced those bearings, it would work great.
                Mike
                Phone: 701-371-5615
                • capitljC Offline
                  capitljC Offline
                  capitlj
                  Cool gald to see im not the only one staying busy
                  > Mitch Hedberg wrote:
                  2004 Impala LS 3.8
                  • CRX_CivicC Offline
                    CRX_CivicC Offline
                    CRX_Civic
                    cool swap, i want boost....
                      wa2fastcamaro
                      Should be fun, with about 240 flywheel hp and 280 torque, it should be a fun winter car. Too bad it weighs about 3500lbs.
                      Gunna mod it a bit though, intercooler, exhaust, different supercharger pulley and reprogram the ecu.
                      Apparently these cars will run a 14 sec 1/4 mile. So maybe have to see next year. :icon_cheers:
                      Phone: 701-371-5615
                      • M Offline
                        M Offline
                        musthavemuzk
                        interesting.
                        as a matter of fact they do run 14's stock. look in my sig.
                        Monty
                        14.59 at 94.85 still stock
                        www.pbase.com/musthavemuzk
                          My grandpa let me play around with his 98 Park Avenue Ultra last summer. God that thing was fun. Quick as hell too.
                          • snow99dohcS Offline
                            snow99dohcS Offline
                            snow99dohc
                            Woot another s/c 3800 around. Just a side note once you start modding it you cant stop, trust me:icon_rabbit: VVVVV
                            2003 Pontiac Gran Prix GTP-4'' FWI, u-bend/resonator delete, 180 degree t-stat, AL 104's, ZZP Pcm, ZZP Stg 1 HV TB, ZZP Front PLOG, ZZP 3'' DP, 3'' custom catback,magnaflow mufflers, 3.4'' pulley.
