  4. My L67 3800 Swap
My L67 3800 Swap
13 Posts 9 Posters 1.9k Views
  • wa2fastcamaroW Offline
    wa2fastcamaro
    bubba;195007 wrote:
    How hard would something like that be to do to a 91 regal with a 3.8 tuned port engine in it at the moment...
    couldn't tell you, I swapped the whole cradle since them were the same, if the motor and tranny bolt up the same then getting it in the car is easy. They you just got to plumb fuel lines and make a wiring harness.
    Mike
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
      Nice work.....so what all did you use out of the donor car and what stayed with the car?? How is the tranny that you pulled (i mite be interested in it)
        Mike
        Ok, cause far as i know it's just basically a series one that's not supercharged...
          wa2fastcamaro
          well the donor car is pretty much gutted as I upgraded most of my 93 to 97 parts, nicer interior, bose radio system, etc...
          Tranny shifted great, but has a bad output shaft bearing. If you replaced those bearings, it would work great.
          Mike
          Phone: 701-371-5615
          • capitljC Offline
            capitljC Offline
            capitlj
            Cool gald to see im not the only one staying busy
            > Mitch Hedberg wrote:
            2004 Impala LS 3.8
            • CRX_CivicC Offline
              CRX_CivicC Offline
              CRX_Civic
              cool swap, i want boost....
                wa2fastcamaro
                Should be fun, with about 240 flywheel hp and 280 torque, it should be a fun winter car. Too bad it weighs about 3500lbs.
                Gunna mod it a bit though, intercooler, exhaust, different supercharger pulley and reprogram the ecu.
                Apparently these cars will run a 14 sec 1/4 mile. So maybe have to see next year. :icon_cheers:
                Phone: 701-371-5615
                • M Offline
                  M Offline
                  musthavemuzk
                  interesting.
                  as a matter of fact they do run 14's stock. look in my sig.
                  Monty
                  14.59 at 94.85 still stock
                  www.pbase.com/musthavemuzk
                    My grandpa let me play around with his 98 Park Avenue Ultra last summer. God that thing was fun. Quick as hell too.
                    • snow99dohcS Offline
                      snow99dohcS Offline
                      snow99dohc
                      Woot another s/c 3800 around. Just a side note once you start modding it you cant stop, trust me:icon_rabbit: VVVVV
                      2003 Pontiac Gran Prix GTP-4'' FWI, u-bend/resonator delete, 180 degree t-stat, AL 104's, ZZP Pcm, ZZP Stg 1 HV TB, ZZP Front PLOG, ZZP 3'' DP, 3'' custom catback,magnaflow mufflers, 3.4'' pulley.
