My L67 3800 Swap
bubba;195007 wrote:
How hard would something like that be to do to a 91 regal with a 3.8 tuned port engine in it at the moment...couldn't tell you, I swapped the whole cradle since them were the same, if the motor and tranny bolt up the same then getting it in the car is easy. They you just got to plumb fuel lines and make a wiring harness.
Mike
Nice work.....so what all did you use out of the donor car and what stayed with the car?? How is the tranny that you pulled (i mite be interested in it)
wa2fastcamaro;195015 wrote:
couldn't tell you, I swapped the whole cradle since them were the same, if the motor and tranny bolt up the same then getting it in the car is easy. They you just got to plumb fuel lines and make a wiring harness.Mike
Ok, cause far as i know it's just basically a series one that's not supercharged...
inspector01;195016 wrote:
Nice work.....so what all did you use out of the donor car and what stayed with the car?? How is the tranny that you pulled (i mite be interested in it)well the donor car is pretty much gutted as I upgraded most of my 93 to 97 parts, nicer interior, bose radio system, etc...
Tranny shifted great, but has a bad output shaft bearing. If you replaced those bearings, it would work great.
Mike
Should be fun, with about 240 flywheel hp and 280 torque, it should be a fun winter car. Too bad it weighs about 3500lbs.
Gunna mod it a bit though, intercooler, exhaust, different supercharger pulley and reprogram the ecu.
Apparently these cars will run a 14 sec 1/4 mile. So maybe have to see next year. :icon_cheers:
interesting.
as a matter of fact they do run 14's stock. look in my sig.
Monty
Woot another s/c 3800 around. Just a side note once you start modding it you cant stop, trust me:icon_rabbit: VVVVV
