  4. S13 240sx Built From MN
18 Posts 13 Posters 2.1k Views
    This is from minneapolis. Its Fucken nice
    http://forums.nasioc.com/forums/showthread.php?t=1464967
      thrash
      Beautiful car.
      Brake fluid resivoirs hidden from view in a race car, behind the dash?
      FAIL
        Sexy.
        • itRfanI Offline
          itRfanI Offline
          itRfan
          daaaaaaamn!!! That is hott!!!
          Waiting for fabers responce......
          -weshole
            FAIL
            why you say fail? i think it's a clever idea
              Wow thats one super nice S13. Wish it was S14 or 15 though.
                thrash
                There are a few reasons
                • in many prepared cars, it's common to have the brake fluid resivoirs on top of the dash (or where the dash would go) on the passenger side. this gives them high visibility and can give you an indication of brake system failure before you've commited yourself to using up 100% of your stopping power. The 240 in this thread offers no visibility of the brake fluid levels
                • even in cars where resivoir visibility is not a concern, the brake fluid system is one of the most serviced systems on the car. putting it behind the instrument cluster seems ridiculous. A diligent crew is checking the fluid level after every session. How easy is it to bleed the brakes here? Is there enough room to attach a pressure bleeder? How much stuff do you have to move out of the way just to check or top off your fluild?
                • brake fluid ruins almost everything it touches. even in a car with a stripped interior, i don't want brake fluid anywhere near anything that matters. i don't want it near my electrical harnesses, and i don't want to have my brake system maintenance tools going over my seats, my steering wheel, etc, when its time to re-bleed the system. I don't think i've ever managed to do a brake fluid job without getting 1 drop of fluid somewhere. That 1 spilled drop (or considerably more, if you make a mistake) may as well not be on the way to getting down inside the dashboard.
                I've never seen it done this way before. The reasons above are ones i can think of that seem disadvantageous. It looks like a nicely prepared car otherwise, so this seems like an uncharacteristic mistake or omission. This may be the work of someone that hasn't been around many prepared road-race cars or hasn't had to do work in the pits.
                  He's already seen it and so have I...long time ago on MNSC...
                    Its an AMAZING car. I would love to own it. I would trade the red car for it..... maybe.
                    It is FAR from a race car. He said he was going to drift it, but never happened. It is more showy then race. That is why the master cylinder is inside the car under the dash. I would do it on my car, as it keeps the fluid and lines away from the hot turbo and manifold.
                      bill
                      Very nice
                        Faber you should buy it
                        • thurmanmermanT Offline
                          thurmanmerman
                          Except his car is RHD therefore his MC would be on the Intake side now.
                          > Parker;299126 wrote:
                          • 99civic9 Offline
                            99civic9 Offline
                            99civic
                            hold on i need to go change my boxers!!! very clean.
                            2000 civic SiR - jdm sickness
                              ^^ I know that. I was saying I should do that.
                                thrash
                                The issue is not that it's inside the car.. it's that it's inside / under the dash.
                                What is the stock JDM setup?
                                  Just like the USDM but everything comes out the other side.
                                  There is really no issue with it being inside until it leaks.
                                    baller ass car. i love it.
                                    • Afsil80A Offline
                                      Afsil80A Offline
                                      Afsil80
                                      Stock JDM setup is on the intake side. All the S-chassis motors are intake on passnger side. The steering column is something that has to be taken into account when a larger than stock elbow/downpipe is being installed.
                                      My only gripe and complaint about the car:
                                      He couldn't have gone bigger than a 2871R? Kinda weak considering everything else he did...
                                      -Peter
                                      1991 240SX
