  4. chevy 350 getting to hot
30 Posts 8 Posters 2.5k Views
  • ParkerP
    ParkerP
    it still sounds like a bad cooling fan clutch....
    BlueSRT0483;244555 wrote:
    Trafik Jamz;260984 wrote:
    You are right Parker.
    • G
      G
      generation_xxx
      id chech the fan clutch, also fan shroud and is it getting the air flow directed thru the core properly
      • zbrownZ
        zbrownZ
        traveling at speed down the highway the fan should be irrelevant
        there should be way more than adequate airflow across the rad. even if the fan was taken off, when traveling down the highway
        • GnArKiLlG
          GnArKiLlG
          GnArKiLl
          its not the fan thats for sure.. i tryed 2 other fans and i know both of thase work because i pulled them off running trucks.. i think the radiator might be cloged, so ill see what i can come up with
          1976 Chevy K5- lifted beater
          • SPANISH-RICES
            SPANISH-RICES
            to many cylinders? jk, you sure youre not losing coolant or something? what fuel do you run?
            • GnArKiLlG
              GnArKiLlG
              GnArKiLl
              i know im not loosing coolant.. and i just run regular gas or ethonal just cheap shit for the trucks...
              • SPANISH-RICES
                SPANISH-RICES
                Detonation?
                • zbrownZ
                  zbrownZ
                  zbrown;236361 wrote:
                  Id pull the thermostat and see what it did..... if the whole system overheats still i would have to think it is a rad problem..
                  I still think it is a rad problem
                  • SPANISH-RICES
                    SPANISH-RICES
                    Koyo
                    • SPANISH-RICES
                      SPANISH-RICES
                      Or honda full rad
                      • GnArKiLlG
                        GnArKiLlG
                        GnArKiLl
                        im going to flush the system out today and see what i get
                        • GnArKiLlG
                          GnArKiLlG
                          GnArKiLl
                          well i flushed the system out and no luck so i think im going to try a new radiator
                          • SPANISH-RICES
                            SPANISH-RICES
                            Thats pretty much all thats left, is that one in rough shape?
                            • GnArKiLlG
                              GnArKiLlG
                              GnArKiLl
                              no not realy.. but im betting its cloged at the bottem
