  4. chevy 350 getting to hot
30 Posts 8 Posters 2.4k Views
    are they solid mounts or do they have a clutch they mount to?
    Like this.http://www.haydenauto.com/products/fan-clutches-and-fan-blades.htm
    • GnArKiLlG Offline
      GnArKiLlG Offline
      GnArKiLl
      they have a clutch... but i did change fans and it still gets hot
      1976 Chevy K5- lifted beater
      • 94civicex9 Offline
        94civicex9 Offline
        94civicex
        check the timing and look for a vaccume leak. thats what was happining with my camaro a couple years ago and it was because the timing was advanced and it had a small vaccume leak, it ran fine too.
        Playtime Performance
        2005 Yamaha R1 [email protected]
        2009 Zuma 125
        1995 Honda Civic DX
        • GnArKiLlG Offline
          GnArKiLlG Offline
          GnArKiLl
          the timing is dead on..
          • BookemB Offline
            BookemB Offline
            Bookem
            What kind of shroud is around the fan? Make sure you have the right fan, s-10 fans and water pumps will bolt right up but have opposite rotation. Also make sure there's no restriction in the exhaust.
            Legacy GT
            Gmc Suburban
            Hallorann: Fargostreet?
            Hallorann: No, I ain't.
              it still sounds like a bad cooling fan clutch....
              • G Offline
                G Offline
                generation_xxx
                id chech the fan clutch, also fan shroud and is it getting the air flow directed thru the core properly
                  traveling at speed down the highway the fan should be irrelevant
                  there should be way more than adequate airflow across the rad. even if the fan was taken off, when traveling down the highway
                  • GnArKiLlG Offline
                    GnArKiLlG Offline
                    GnArKiLl
                    its not the fan thats for sure.. i tryed 2 other fans and i know both of thase work because i pulled them off running trucks.. i think the radiator might be cloged, so ill see what i can come up with
                      to many cylinders? jk, you sure youre not losing coolant or something? what fuel do you run?
                      • GnArKiLlG Offline
                        GnArKiLlG Offline
                        GnArKiLl
                        i know im not loosing coolant.. and i just run regular gas or ethonal just cheap shit for the trucks...
                          Detonation?
                            zbrown;236361 wrote:
                            Id pull the thermostat and see what it did..... if the whole system overheats still i would have to think it is a rad problem..
                            I still think it is a rad problem
                              Koyo
                                Or honda full rad
                                • GnArKiLlG Offline
                                  GnArKiLlG Offline
                                  GnArKiLl
                                  im going to flush the system out today and see what i get
                                  • GnArKiLlG Offline
                                    GnArKiLlG Offline
                                    GnArKiLl
                                    well i flushed the system out and no luck so i think im going to try a new radiator
                                      Thats pretty much all thats left, is that one in rough shape?
                                      • GnArKiLlG Offline
                                        GnArKiLlG Offline
                                        GnArKiLl
                                        no not realy.. but im betting its cloged at the bottem
