Knowledgeable person to help start my LS/VTEC
well it has been sitting forever so bad gas is likely.
also i would ad maybe your base map is just way the eff off. you never know
Slowica;246664 wrote:
distributor set right?It should be...i just set it at 0 when i put it back on. I'll try putting a tank of good gas in it and see where that gets me
GreenLantern;246719 wrote:
It should be...i just set it at 0 when i put it back on. I'll try putting a tank of good gas in it and see where that gets meIt is sposed to be 16* btdc and you need a timing light to set it correctly, but it should idle if it is close.
I'll check that the next time i go over and work on it
XJHEAD;246766 wrote:
180* out, maybe not possible on those.???The dizzy won't go 180* off on a honda, unless obviously the cams or tdc was off.
inspector01;246767 wrote:
The dizzy won't go 180* off on a honda, unless obviously the cams or tdc was off.how about wires backwards then..
wasn't sure about that. That import shit is wasy too complicated for me..
If I cannot work on it with a pair of plyers, a couple screwdrivers, a pipewrench and a bfh I won't touch it.
Slowica;246787 wrote:
thought he said tintmasters did the timing... dont think they would make that mistake.I know, I was just saying that it's been done before.. and the car i'm talking bout wasnt a bad timing job, it happend to jump belt that far or something like that... I'm sure if kyle did the timing it'd have been done right.
still not workin
If someone is truly confident in their skill at gettin shit to work, give me a call and you can try your hand at it. The lucky winner to get it to run gets no less than $100 cash.
...just a little incentive
701 739 0046 Adam (my cell)
Ill check it out when i am back in about 3 weeks.
inspector01;247705 wrote:
Ill check it out when i am back in about 3 weeks.I appreciate it a lot and i would love to have some help; however, i'm hoping to have it done sooner rather than later. I haven't had a car since last Christmas and need my baby back on the pavement stat
If anyone can get my hoop-dee runnin, i'll give them $200 cash on the spot. No questions asked. The end
Consider it because i need my baby back asap
