Knowledgeable person to help start my LS/VTEC
I've been working on my built LS/VTEC for a while now and i can't get it to start. This is my first engine swap in a Honda and my first LS/VTEC. Its already in the car, but i'm sure i'm missing something simple that's causing it to not start.
If anyone in the area is knowledgeable about this kind of thing and confident they can get my car running, either post here or give me a call (701-739-0046). I'm willing to pay for your services. Thanks.
-adam
gsrEK;246556 wrote:
get new main relayI tried that a while back, but nothing happened. I'd be a little hesitant to buy another and try it since they dont let you return them and they're $80. If someone has one and would let me try it, i'd be willing to compensate for their time and effort.
It did start and sputter a few times but then i changed plugs and put the new 3bar map on and it wont do anything now. It does have compression and i know the cam timing is on since TintMasters set it for me like a week and a half ago...
MisterCMK;246563 wrote:
Adam, if you can wait until Tuesday I'd be more than willing to help you out with it.Why thank you sir. I really want to get my hoop-dee running because i'm a little sick of catchin rides everywhere when i have a perfectly "good" car sitting in the garage
What EMS?? What map is in it?? Do you have spark?? Do you have fuel??
What is it doing?? I could check it out but i won't be around for a month.
Yes its boosted and the 3 bar is wired correctly. Its running Crome, i have spark, i have fuel. It used to sputter and idle around 200rpm, but die once i gave it gas. Now it doesn't even attempt to fire.
well it has been sitting forever so bad gas is likely.
also i would ad maybe your base map is just way the eff off. you never know
Slowica;246664 wrote:
distributor set right?It should be...i just set it at 0 when i put it back on. I'll try putting a tank of good gas in it and see where that gets me
GreenLantern;246719 wrote:
It should be...i just set it at 0 when i put it back on. I'll try putting a tank of good gas in it and see where that gets meIt is sposed to be 16* btdc and you need a timing light to set it correctly, but it should idle if it is close.
I'll check that the next time i go over and work on it
XJHEAD;246766 wrote:
180* out, maybe not possible on those.???The dizzy won't go 180* off on a honda, unless obviously the cams or tdc was off.
inspector01;246767 wrote:
The dizzy won't go 180* off on a honda, unless obviously the cams or tdc was off.how about wires backwards then..
wasn't sure about that. That import shit is wasy too complicated for me..
If I cannot work on it with a pair of plyers, a couple screwdrivers, a pipewrench and a bfh I won't touch it.
