Epoxy removal
I need to un-epoxy some magnets from an aluminum cam gear. I tried heating the crap out of the thing, hoping the epoxy would soften but no luck. I've read on the internet that acetone will soften the epoxy, has anyone tried this or any other recommendations on getting epoxy to let go?
http://www.wmbarr.com/product.aspx?catid=72&prodid=135
I dont know if its safe to use on aluminum
I dont know if this particular brand is good but the aircraft paint remover should do it. -
kleen strip aircraft remover?
The magnets are 1/8" diameter by 1/4" deep. The cam gears are drilled so that the magnets drop into a 1/8" hole and are flush with the surface of the gear. Then a little epoxy is poured in the hole and the magnet set in. I haven't tried to drill or machine the magnets yet, I put two in incorrectly and hate to have to start all over with a new gear. There are 13 magnets in the gear, and a new set of magnets is $80.
