  4. Epoxy removal
Epoxy removal
15 Posts 7 Posters 890 Views
    do you the magnets need to be reused?
    Sounds like a dumb question, but i am not positive they need to be salvaged if you say you were heating them...... unless you were using a heat gun, and in my head you were using a rose bud. haha
    • vss2kV Offline
      vss2kV Offline
      vss2k
      Paint Removers such as Old Masters TM-4 would work well because they are heavy bodied almost like a paste for vertical surfaces. Make sure to wear gloves, beacause it burns. TM-4 has the ability to remove up to 15 layers at a time, so it should suffice for epoxy
      Team EMOTION
      TSCatalyst.com
      • 63vette6 Offline
        63vette6 Offline
        63vette
        Methylene Chloride is the only chemical that will touch it. It also causes more health hazards than I would be willing to deal with. I would replace the cam gear sensor Mr. Moneybags. 🙂
          kleen strip aircraft remover?
          • 63vette6 Offline
            63vette6 Offline
            63vette
            fishin... did someone say fishin? I know fishin. 🙂
            • XJHEADX Offline
              XJHEADX Offline
              63vette;260597 wrote:
              Methylene Chloride is the only chemical that will touch it. It also causes more health hazards that I have to deal with.
              That explains a lot..
              • XJHEADX Offline
                XJHEADX Offline
                Try freezing it and a good whack. Use a can of freon, spray it upside down to get the liquid on it.
                  lol cuz thats legal..........
                  not that I care. lol
                  • 63vette6 Offline
                    63vette6 Offline
                    63vette
                    Unhook the freon line from your homes central air, point it an the part, have a beer, chuckle and go back inside.
                    Then use a 12lb hammer, it will pop right off........in little pieces. 🙂
                    Come on! Its magnets, freezing them and hitting them wont ruin them right?
                    • XJHEADX Offline
                      XJHEADX Offline
                      Where did he say he was re-using them?
                      • 63vette6 Offline
                        63vette6 Offline
                        63vette
                        Oh, thats different. Then just cut them off with a dremel and clean the excess off with a razor blade and some emery cloth.
                          The magnets are 1/8" diameter by 1/4" deep. The cam gears are drilled so that the magnets drop into a 1/8" hole and are flush with the surface of the gear. Then a little epoxy is poured in the hole and the magnet set in. I haven't tried to drill or machine the magnets yet, I put two in incorrectly and hate to have to start all over with a new gear. There are 13 magnets in the gear, and a new set of magnets is $80. 😕
                          • XJHEADX Offline
                            XJHEADX Offline
                            Can you drill the backside with a small bit and try to push them out?
