  4. Epoxy removal
Epoxy removal
15 Posts 7 Posters 1.2k Views
  • RexwagonR
    RexwagonR
    http://www.wmbarr.com/product.aspx?catid=72&prodid=135
    I dont know if its safe to use on aluminum
    I dont know if this particular brand is good but the aircraft paint remover should do it.
    • zbrownZ
      zbrownZ
      do you the magnets need to be reused?
      Sounds like a dumb question, but i am not positive they need to be salvaged if you say you were heating them...... unless you were using a heat gun, and in my head you were using a rose bud. haha
      • vss2kV
        vss2kV
        vss2k
        Paint Removers such as Old Masters TM-4 would work well because they are heavy bodied almost like a paste for vertical surfaces. Make sure to wear gloves, beacause it burns. TM-4 has the ability to remove up to 15 layers at a time, so it should suffice for epoxy
        Team EMOTION
        TSCatalyst.com
        • 63vette6
          63vette6
          63vette
          Methylene Chloride is the only chemical that will touch it. It also causes more health hazards than I would be willing to deal with. I would replace the cam gear sensor Mr. Moneybags. 🙂
          • 24valvenotak2
            24valvenotak2
            kleen strip aircraft remover?
            63vette;288530 wrote:
            • 63vette6
              63vette6
              63vette
              fishin... did someone say fishin? I know fishin. 🙂
              • XJHEADX
                XJHEADX
                63vette;260597 wrote:
                Methylene Chloride is the only chemical that will touch it. It also causes more health hazards that I have to deal with.
                That explains a lot..
                • XJHEADX
                  XJHEADX
                  Try freezing it and a good whack. Use a can of freon, spray it upside down to get the liquid on it.
                  • RexwagonR
                    RexwagonR
                    lol cuz thats legal..........
                    not that I care. lol
                    • 63vette6
                      63vette6
                      63vette
                      Unhook the freon line from your homes central air, point it an the part, have a beer, chuckle and go back inside.
                      Then use a 12lb hammer, it will pop right off........in little pieces. 🙂
                      Come on! Its magnets, freezing them and hitting them wont ruin them right?
                      • XJHEADX
                        XJHEADX
                        Where did he say he was re-using them?
                        • 63vette6
                          63vette6
                          63vette
                          Oh, thats different. Then just cut them off with a dremel and clean the excess off with a razor blade and some emery cloth.
                          • DaveHD
                            DaveHD
                            The magnets are 1/8" diameter by 1/4" deep. The cam gears are drilled so that the magnets drop into a 1/8" hole and are flush with the surface of the gear. Then a little epoxy is poured in the hole and the magnet set in. I haven't tried to drill or machine the magnets yet, I put two in incorrectly and hate to have to start all over with a new gear. There are 13 magnets in the gear, and a new set of magnets is $80. 😕
                            • XJHEADX
                              XJHEADX
                              Can you drill the backside with a small bit and try to push them out?
