  4. Car Updates / Progress
  5. Update on the stang
Update on the stang
29 Posts 14 Posters 7.0k Views
  • ruthless351R
    ruthless351R
    ruthless351
    XJHEAD;267234 wrote:
    Take the A/C out and put the top down. Oops never mind.
    I have a 272 @ .050 with .714 lift you can try too...
    I bet!
    • ruthless351R
      ruthless351R
      ruthless351
      I also just finished my 3g conversion tonight. Its a upgrade from the standard 2g (75 amp) alternator to the 3g (130 amp). Now i have enough juice to power that electric cooling fan, stereo, and high volume fuel pump!
      From this......75amp
      To this...130 amp
      • capitljC
        capitljC
        capitlj
        The 3G alts look soooo much better.
        Mitch Hedberg wrote:
        2004 Impala LS 3.8
        • ChristianC
          ChristianC
          Christian
          I put a 3g on my vert a couple years ago they still don't charge well at a idle.
          Playtime Performance
          06 F-150 Lariat
          • ruthless351R
            ruthless351R
            ruthless351
            Did you swap the pulley from the 2g to the 3g? That is supposed to help the charge at idle issue. I will have to see what mine does after everything is done. Last night it was charging at around 14.3-14.8. As for amps i dont know yet.
            • ChristianC
              ChristianC
              Christian
              Don't remember but I think I have a couple laying around and I'll have to try that. Thanks.
              06 F-150 Lariat
              • ruthless351R
                ruthless351R
                ruthless351
                Started on the head swap tonight, but had to stop cuz i left my AC disconnect tools at work.
                • C
                  C
                  Chirp5957
                  gt40 heads = Thumbs up! mpg down lol
                  1996 cobra 13.20 @106
                  4.10 gears
                  short throw shift
                  off road x pipe
                  BBK Cold Air
                  Diablo chip
                  BBK LT
                  • MisterCMKM
                    MisterCMKM
                    Still weaksauce
                    Should gone with the trickflow heads
                    thrash;315544 wrote:
                    Ford is back :)
                    • GrrG
                      GrrG
                      word, still not gonna make much power, an improvement none the less though
                      • ruthless351R
                        ruthless351R
                        ruthless351
                        Couldnt come up with the cash for the whole head swap with rockers and pushrods and stuff. I'll do some nice heads for my next build.
                        • ruthless351R
                          ruthless351R
                          ruthless351
                          Finished the job today. Looks so much better without the A/C and clutch fan. Check it out.
                          Prepping for the new heads to go on.
                          Everything installed and wired
                          • p-351P
                            p-351P
                            p-351
                            Looks good---but damn that's a long stretch between the PS and Alt without the tensioner there....
                            My Supermotors page: http://www.supermotors.net/users/p-351
                            My AMSOIL dealer site: http://www.redriversynthetics.net
                            • C
                              C
                              Cobra Rob
                              Good job man
                              • ruthless351R
                                ruthless351R
                                ruthless351
                                I noticed cylinder 5 using way too much oil and almost bridged the spark plug gap so i decided to tear the heads back off. I was way too eager to get the heads on and running so i cleaned up the heads, and valves without checking the guides and cutting valves and seats. I know i know it was dumb but i had fun with the car for a summer. Guides on cyl 5 were shot.
                                The heads are compleatly rebuilt with fresh 3 angle valve job, guides repaired and valves cut. I feel good about these heads now. Thats it for an update for now. On the hunt for an ignition box , injectors and a MAF now.
                                • capitljC
                                  capitljC
                                  capitlj
                                  Are you doing the work at the shop?
                                  2004 Impala LS 3.8
                                  • ruthless351R
                                    ruthless351R
                                    ruthless351
                                    Nope....the car is out at my brothers farm.
