  4. For Sale - PROSPORT Electric Boost/Vac Gauge
18 Posts 6 Posters 1.5k Views
  • C
    C
    ChrisNelson
    This gauge has never been installed and is new in the box. I powered it up to test and that is it. These are the really neat looking gauges that look black/blank when off, and then light up with an "opening ceremony" when the ignition is turned on.
    52mm Electrical Boost/Vacuum Gauge with Sensor
    Blue Back Lighting
    Sells new for $55 + shipping
    Asking $50 shipped
    WWW.PROSPORTGAUGES.COM
    Watch this video:
    [ame]http://www.youtube.com/watch?v=Z0WVHJemtYQ[/ame]
    www.regionaltop5.com
    • SPANISH-RICES
      SPANISH-RICES
      great gauges i love mine.
      • dodee929D
        dodee929D
        dodee929
        if you still have it on friday i want this for i will have money to buy it.. do you take paypal???
        Amigos Three
        • dodee929D
          dodee929D
          dodee929
          i found out that this will not work in my car due to that it's an 88 so the electronics aren't equipped well enough sorry
          Amigos Three
          • PSiedTSiP
            PSiedTSiP
            • 925JL9259
              925JL9259
              925JL925
              Is this the blue performance series or the blue/white performance series?
              95 TSI
              • C
                C
                ChrisNelson
                I am pretty sure that it is the standard blue series, not blue/white.
                I looked at the receipt and it said "Super Blue".
                • SPANISH-RICES
                  SPANISH-RICES
                  what do you mean? all you need is 12v
                  • C
                    C
                    ChrisNelson
                    haha, yea, that's what I was thinkin...
                    • PSiedTSiP
                      PSiedTSiP
                      I had a post typed out right after he posted that. I changed my mind to see if anyone else would call him out on that.
                      • Bp-08B
                        Bp-08B
                        Bp-08
                        Haha me too
                        • dodee929D
                          dodee929D
                          dodee929
                          i was told that the boost level is all done by electronics and not by vacuum lines on this gauge or is it?? and does it come with the Tubing kit, T-Adaptor, Electric Sender, quick connect pigtail wiring, Visor, Decal and Instructions)
                          Amigos Three
                          • C
                            C
                            ChrisNelson
                            New In Box, Parts List:
                            52mm Boost/Vac Gauge
                            Gauge Wire Harness (Power, Ground, Illum., Sensor)
                            Mounting Bracket & Hardware
                            Visor
                            Vacuum Line "T"
                            Vacuum Line Sender (Plug into any vac line)
                            Extra Vacuum Line
                            PROSPORT Stickers
                            Basically you tap into any vacuum line with the supplied T and extra line then send 1 wire into the cab where your gauge is and hook it up to the gauge.
                            The gauge has power and ground, and the sender has a power and ground. Hook all those wires up then connect the green wire from the sensor to the gauge and it's all done.
                            probably the easiest style boost gauge ever invented. 🙂
                            • C
                              C
                              ChrisNelson
                              Here is a picture of a used one I found on the internet to give you an example of the sender and the gauge:
                              • dodee929D
                                dodee929D
                                dodee929
                                what exactly is the sender for??
                                Amigos Three
                                • C
                                  C
                                  ChrisNelson
                                  It is a sensor that sends a signal to the gauge. Uses the sender instead of a mechanical line.
                                  Makes it so you don't have to run a vacuum hose all the way into the engine compartment.
                                  • dodee929D
                                    dodee929D
                                    dodee929
                                    so do you take paypal?
                                    Amigos Three
                                    • C
                                      C
                                      ChrisNelson
                                      sure
                                      PM sent
