  4. For Sale - PROSPORT Electric Boost/Vac Gauge
18 Posts 6 Posters 1.5k Views
  • dodee929D
    dodee929D
    dodee929
    if you still have it on friday i want this for i will have money to buy it.. do you take paypal???
    Amigos Three
    • dodee929D
      dodee929D
      dodee929
      i found out that this will not work in my car due to that it's an 88 so the electronics aren't equipped well enough sorry
      Amigos Three
      • PSiedTSiP
        PSiedTSiP
        • 925JL9259
          925JL9259
          925JL925
          Is this the blue performance series or the blue/white performance series?
          95 TSI
          • C
            C
            ChrisNelson
            I am pretty sure that it is the standard blue series, not blue/white.
            I looked at the receipt and it said "Super Blue".
            www.regionaltop5.com
            • SPANISH-RICES
              SPANISH-RICES
              what do you mean? all you need is 12v
              • C
                C
                ChrisNelson
                haha, yea, that's what I was thinkin...
                • PSiedTSiP
                  PSiedTSiP
                  I had a post typed out right after he posted that. I changed my mind to see if anyone else would call him out on that.
                  • Bp-08B
                    Bp-08B
                    Bp-08
                    Haha me too
                    • dodee929D
                      dodee929D
                      dodee929
                      i was told that the boost level is all done by electronics and not by vacuum lines on this gauge or is it?? and does it come with the Tubing kit, T-Adaptor, Electric Sender, quick connect pigtail wiring, Visor, Decal and Instructions)
                      Amigos Three
                      • C
                        C
                        ChrisNelson
                        New In Box, Parts List:
                        52mm Boost/Vac Gauge
                        Gauge Wire Harness (Power, Ground, Illum., Sensor)
                        Mounting Bracket & Hardware
                        Visor
                        Vacuum Line "T"
                        Vacuum Line Sender (Plug into any vac line)
                        Extra Vacuum Line
                        PROSPORT Stickers
                        Basically you tap into any vacuum line with the supplied T and extra line then send 1 wire into the cab where your gauge is and hook it up to the gauge.
                        The gauge has power and ground, and the sender has a power and ground. Hook all those wires up then connect the green wire from the sensor to the gauge and it's all done.
                        probably the easiest style boost gauge ever invented. 🙂
                        • C
                          C
                          ChrisNelson
                          Here is a picture of a used one I found on the internet to give you an example of the sender and the gauge:
                          • dodee929D
                            dodee929D
                            dodee929
                            what exactly is the sender for??
                            Amigos Three
                            • C
                              C
                              ChrisNelson
                              It is a sensor that sends a signal to the gauge. Uses the sender instead of a mechanical line.
                              Makes it so you don't have to run a vacuum hose all the way into the engine compartment.
                              • dodee929D
                                dodee929D
                                dodee929
                                so do you take paypal?
                                Amigos Three
                                • C
                                  C
                                  ChrisNelson
                                  sure
                                  PM sent
