For Sale - PROSPORT Electric Boost/Vac Gauge
I am pretty sure that it is the standard blue series, not blue/white.
I looked at the receipt and it said "Super Blue".
dodee929;269898 wrote:
i found out that this will not work in my car due to that it's an 88 so the electronics aren't equipped well enough sorrywhat do you mean? all you need is 12v
haha, yea, that's what I was thinkin...
New In Box, Parts List:
52mm Boost/Vac Gauge
Gauge Wire Harness (Power, Ground, Illum., Sensor)
Mounting Bracket & Hardware
Visor
Vacuum Line "T"
Vacuum Line Sender (Plug into any vac line)
Extra Vacuum Line
PROSPORT StickersBasically you tap into any vacuum line with the supplied T and extra line then send 1 wire into the cab where your gauge is and hook it up to the gauge.
The gauge has power and ground, and the sender has a power and ground. Hook all those wires up then connect the green wire from the sensor to the gauge and it's all done.
probably the easiest style boost gauge ever invented.
Here is a picture of a used one I found on the internet to give you an example of the sender and the gauge:
It is a sensor that sends a signal to the gauge. Uses the sender instead of a mechanical line.
Makes it so you don't have to run a vacuum hose all the way into the engine compartment.
sure
PM sent
