  3. Wanted Ads
  4. Anyone have an engine hoist or engine stand I can use ASAP willing to pay!
28 Posts 10 Posters 1.3k Views
  • Bp-08B Offline
    Bp-08B Offline
    Bp-08
    Like I said I have a hoist and its not being used, say 10 bucks and you can pick it up and borrow it. It folds up so transporting it shouldnt be too bad.
      ihaveaids;284623 wrote:
      Why take it all apart when you could just pull the whole motor and trans assembly out with a hoist? And the jack doesn't come close to lifting the car high enough.
      And how do you get the axle out of the hub without separating the ball joint? Just curious because that how I have always done it.
      well you can get a real car jack for starters... haha j/k. but if your jack can't go high enough you can do what i had mentioned earlier and drop the car onto the jack (say 3-4" off ground). this lets you lift the motor out of the engine bay, ef's allow you to pull the motor through the radiator support hole once the radiator is removed.
      the reason i told him to do it this way was he seamed desperate and in need of help, and no one had a hoist. so plan b pull the bitch out with the bare hands. it would have been done in about 2 hours if he would have done it... :icon_scratch:
      regarding the axle/ball joint situation. you pull the 2 nuts that hold the upper a arm onto the shock tower, this allows the a-arm/hub assembly to swing out of the way, this allows you to slip the axle out of the hub. very simple and there is no ball joint to cross thread. only minor issue is watching to not let the hub hang by the brake line. this can tear the line. just don't be stupid.
        Really?? You must not be very creative. I have pulled motors out the bottom with small floor jacks, you can put blocks on the jack, or the jack on a block or something. And as matt explained, you can easily get the axles out without touching the ball joints.
        • BassplayerB Offline
          BassplayerB Offline
          Bassplayer
          Thats awesome thanks for letting us know that! I never would have thought of doing it that way, I guess I just learned that you had to separate the ball joint to get the axle out.:icon_cheers:
          1995 GMC Sierra
          • Gundar1G Offline
            Gundar1G Offline
            Gundar1
            Or use the hoist to lift the car up and slide the motor and tranny out from underneath the car.
            EVO
            • Bp-08B Offline
              Bp-08B Offline
              Bp-08
              Or use the cherry picker to lift out motor/trans like normal people.
                bp, have you ever pulled a motor on a ef? because i have many times, and i can tell you that pulling the engine/trans as one isn't very easy. as the engine bay is tiny. oh and if these kids can't figure out how to pull a motor you think they have the ability to pull the roll pin in the shift linkage and pull that before wraping around the bottom of the car.
                bp quit talking please.
                • Gundar1G Offline
                  Gundar1G Offline
                  Gundar1
                  Ive done it both ways lifing the car up is alot easier.
                  EVO
                    please tell me how lifting a car with a hoist is better. this sounds stupid.
                    also where the fuck you lifting the car from? :drunken_smilie:
                    • blackcherryTSiB Offline
                      blackcherryTSi
                      lol... truth
                      1995 Honda Civic
                        Umm... if it were me, i'd just use the cherry picker... i've done it many ways, out the bottom, bare hands, etc... cherry picker seemed to be the easiest...
                          seriously the point was that he didn't have one. bubba you fail
                            ya, but if it takes him all of 20mins to drive across town and get one, might as well
                              in those 20 min, i would have had the engine half out. and not wasted the money to "rent" a hoist.
                                So did this motor ever make its way out of the car? If so post some pictures.
