  3. Wanted Ads
  4. Anyone have an engine hoist or engine stand I can use ASAP willing to pay!
28 Posts 10 Posters 1.5k Views
    ihaveaids;284623 wrote:
    Why take it all apart when you could just pull the whole motor and trans assembly out with a hoist? And the jack doesn't come close to lifting the car high enough.
    And how do you get the axle out of the hub without separating the ball joint? Just curious because that how I have always done it.
    Really?? You must not be very creative. I have pulled motors out the bottom with small floor jacks, you can put blocks on the jack, or the jack on a block or something. And as matt explained, you can easily get the axles out without touching the ball joints.
    • BassplayerB Offline
      BassplayerB Offline
      Bassplayer
      DrifterExtreme;284626 wrote:
      regarding the axle/ball joint situation. you pull the 2 nuts that hold the upper a arm onto the shock tower, this allows the a-arm/hub assembly to swing out of the way, this allows you to slip the axle out of the hub. very simple and there is no ball joint to cross thread. only minor issue is watching to not let the hub hang by the brake line. this can tear the line. just don't be stupid.
      Thats awesome thanks for letting us know that! I never would have thought of doing it that way, I guess I just learned that you had to separate the ball joint to get the axle out.:icon_cheers:
      1995 GMC Sierra
      • Gundar1G Offline
        Gundar1G Offline
        Gundar1
        Or use the hoist to lift the car up and slide the motor and tranny out from underneath the car.
        EVO
        • Bp-08B Offline
          Bp-08B Offline
          Bp-08
          Or use the cherry picker to lift out motor/trans like normal people.
            bp, have you ever pulled a motor on a ef? because i have many times, and i can tell you that pulling the engine/trans as one isn't very easy. as the engine bay is tiny. oh and if these kids can't figure out how to pull a motor you think they have the ability to pull the roll pin in the shift linkage and pull that before wraping around the bottom of the car.
            bp quit talking please.
            • Gundar1G Offline
              Gundar1G Offline
              Gundar1
              Ive done it both ways lifing the car up is alot easier.
              EVO
                please tell me how lifting a car with a hoist is better. this sounds stupid.
                also where the fuck you lifting the car from? :drunken_smilie:
                • blackcherryTSiB Offline
                  blackcherryTSi
                  lol... truth
                  1995 Honda Civic
                    Umm... if it were me, i'd just use the cherry picker... i've done it many ways, out the bottom, bare hands, etc... cherry picker seemed to be the easiest...
                      seriously the point was that he didn't have one. bubba you fail
                        ya, but if it takes him all of 20mins to drive across town and get one, might as well
                          in those 20 min, i would have had the engine half out. and not wasted the money to "rent" a hoist.
                            So did this motor ever make its way out of the car? If so post some pictures.
