  4. HELP! How do you tighten this clamp???
20 Posts 12 Posters 1.8k Views
  • BassplayerB Offline
    BassplayerB Offline
    Bassplayer
    I'm putting a new CV boot on and I can't fucking figure out how to get this clamp to tighten. Anybody have a clue how it works? It doesn't just pull tight...:icon_scratch:
    1995 GMC Sierra
    • gsrEKG Offline
      gsrEKG Offline
      gsrEK
      gota get a special clamp tool or bust ur hand trying to with a pliers
      2009 Yamaha Zuma 125, gas HOG
      2008 Honda Fit daily
      A s2k
      1991 Honda civic DX Mint SOLD
      1988 Mitsubishi Mighty max
      > BlackEJ8;233529 wrote:
        Awww "Grips" can't do it with out a special tool!?
          If you really have to ask this question, you should not be doing the job. But if you insist, there is a special tool for the job.
          • gsrEKG Offline
            gsrEKG Offline
            gsrEK
            O I could with my pliers and my "GRIPS"
            A s2k
            • ticklemedalyT Offline
              ticklemedaly
              side cutters/dikes will work just fine to tighten up that band
              XBL G-tag: TickleMeDaly83
                that and a punch will do the trick
                • capitljC Offline
                  capitljC Offline
                  capitlj
                  Or you can go to Oreilly and get the proper tool for like $8
                  Edit $9.99 I just looked.
                  > Mitch Hedberg wrote:
                  2004 Impala LS 3.8
                  • darkelvisD Offline
                    darkelvisD Offline
                    darkelvis
                    depends on the style clamp...there are two common ones...both have special tools to do it but both can be done without them....pics of clamp.
                      BassplayerB Offline
                      Bassplayer
                      Here are the pics of the clamp. What tool is it?
                      1995 GMC Sierra
                      • capitljC Offline
                        capitljC Offline
                        capitlj
                        Its the $9.99 I sell and then that job is easy as pie.
                        2004 Impala LS 3.8
                          darkelvisD Offline
                          darkelvis
                          those clamps are GARBAGE...if you want any of your grease to stay in that joint then go buy the other style clamp. if you need to use that one then I would suggest getting the tool to do it...you can do it without the tool but it will fail even sooner. 🙂
                            BassplayerB Offline
                            Bassplayer
                            What clamp do you suggest? If it's something that's cheaper than the $9.99 tool and doesn't require me to buy another tool I'll definitely buy the ones you suggest....
                            1995 GMC Sierra
                              darkelvisD Offline
                              darkelvis
                              I'm not sure what the name of the clamp is but it is a "pinch style" clamp...there is a special tool to do it...but a pair of side cutters will work just fine with them as long as you don't actually cut the clamp in the process....
                              kinda hard to see...but this guy uses the style clamp that is better...http://www.hasengeeks.com/projects.php?page=axles
                                darkelvisD Offline
                                darkelvis
                                so does this guy...
                                http://forums.vwvortex.com/zerothread?id=3344208
                                  just buy an aftermarket axle their like 99 bucks. lifetime warranty.
                                  or buy the correct tool and do it right, ive had great luck with those clamps if you do it right
                                    Those are called Oetiker clamps. I think I paid something like $30 for the Oetiker/Knipex tool for them.
                                      thrash
                                      i have the tool that will work on the style clamp you already have if you want to borrow it. if you think you'll ever buy this type of clamp or do this job again, you may as well buy the tool, but whatever. LMK if you want to pick it up. I'll take a $10 deposit. You give me back a working tool, I give you back your working $10 🙂
                                        Just use a big zip tie, nip off the excess and call it a day. 😄
                                          worked for me for four years
