  4. HELP! How do you tighten this clamp???
20 Posts 12 Posters 1.8k Views
  • gsrEKG Offline
    gsrEKG Offline
    gsrEK
    Bryce;285772 wrote:
    Awww "Grips" can't do it with out a special tool!?
    O I could with my pliers and my "GRIPS"
    2009 Yamaha Zuma 125, gas HOG
    2008 Honda Fit daily
    A s2k
    1991 Honda civic DX Mint SOLD
    1988 Mitsubishi Mighty max
    > BlackEJ8;233529 wrote:
    • ticklemedalyT Offline
      ticklemedaly
      side cutters/dikes will work just fine to tighten up that band
      XBL G-tag: TickleMeDaly83
        that and a punch will do the trick
        • capitljC Offline
          capitljC Offline
          capitlj
          Or you can go to Oreilly and get the proper tool for like $8
          Edit $9.99 I just looked.
          > Mitch Hedberg wrote:
          2004 Impala LS 3.8
          • darkelvisD Offline
            darkelvisD Offline
            darkelvis
            depends on the style clamp...there are two common ones...both have special tools to do it but both can be done without them....pics of clamp.
            • BassplayerB Offline
              BassplayerB Offline
              Bassplayer
              Here are the pics of the clamp. What tool is it?
              1995 GMC Sierra
              • capitljC Offline
                capitljC Offline
                capitlj
                Its the $9.99 I sell and then that job is easy as pie.
                2004 Impala LS 3.8
                  darkelvisD Offline
                  darkelvis
                  those clamps are GARBAGE...if you want any of your grease to stay in that joint then go buy the other style clamp. if you need to use that one then I would suggest getting the tool to do it...you can do it without the tool but it will fail even sooner. 🙂
                    BassplayerB Offline
                    Bassplayer
                    What clamp do you suggest? If it's something that's cheaper than the $9.99 tool and doesn't require me to buy another tool I'll definitely buy the ones you suggest....
                    1995 GMC Sierra
                      darkelvisD Offline
                      darkelvis
                      I'm not sure what the name of the clamp is but it is a "pinch style" clamp...there is a special tool to do it...but a pair of side cutters will work just fine with them as long as you don't actually cut the clamp in the process....
                      kinda hard to see...but this guy uses the style clamp that is better...http://www.hasengeeks.com/projects.php?page=axles
                        darkelvisD Offline
                        darkelvis
                        so does this guy...
                        http://forums.vwvortex.com/zerothread?id=3344208
                          just buy an aftermarket axle their like 99 bucks. lifetime warranty.
                          or buy the correct tool and do it right, ive had great luck with those clamps if you do it right
                            Those are called Oetiker clamps. I think I paid something like $30 for the Oetiker/Knipex tool for them.
                              thrash
                              i have the tool that will work on the style clamp you already have if you want to borrow it. if you think you'll ever buy this type of clamp or do this job again, you may as well buy the tool, but whatever. LMK if you want to pick it up. I'll take a $10 deposit. You give me back a working tool, I give you back your working $10 🙂
                                Just use a big zip tie, nip off the excess and call it a day. 😄
                                  worked for me for four years
