  4. The DD
The DD
26 Posts 10 Posters 5.0k Views
  • JN210J Offline
    JN210J Offline
    JN210
    lol...it makes me kinda sad actually, but the Z should be just as fast (or faster) when its put back together, waiting on junk and cleaning / chroming parts.
    *1989 Nissan 300ZX Z31 *
    > DelSlow;262050 wrote:
    > I like the new JN210
      Chroming eh
      • JN210J Offline
        JN210J Offline
        JN210
        im not doing it myself, im just bringing parts to the place. Just valve covers.
          DelSlow;318928 wrote:
          Chroming eh
          adds more power duh...
          • JN210J Offline
            JN210J Offline
            JN210
            QFT!
              JN210;318938 wrote:
              QFT!
              Youre too easy.
              • JN210J Offline
                JN210J Offline
                JN210
                DelSlow;318941 wrote:
                Youre too easy.
                I told your mother the same thing!
                  JN210;318878 wrote:
                  idk, its faster than what im use to though. Ive been driving a 98 avenger
                  ...and an NA 300zx.
                  • Seven1S Offline
                    Seven1S Offline
                    Seven1
                    JN210;318880 wrote:
                    ah ok, I will try to not. Ive heard the Northstars fry rings like none other
                    Nope, blown head gaskets and half case seal leaks are the major downfalls of this motor. Change the coolant out if you haven't already, coolant passages were cast too close to the threads that holds the cylinder heads down, dirty coolant can cause corrosion near the threads and cause cylinder head bolts to let go. Be sure to use HDD(high Zn,Ph) oil, that generation N*'s use flat tappet cams. Beat on the motor, it's good for it, N*'s are extremely durable and respond well to an italian tune up. If a head gasket does let go check out this thread
                    http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/122898-northstar-headgasket-bolt-failure-please-let.html
                      PSiedTSi;319091 wrote:
                      ...and an NA 300zx.
                      Lol.....
                      • capitljC Offline
                        capitljC Offline
                        capitlj
                        Those are nice cars and a 15 second quarter stock stomps what most of us dd.
                        > Mitch Hedberg wrote:
                        2004 Impala LS 3.8
