My project
got some picture's of my progress
How big of a throttle body is common on one of those engines? I'm only familiar with the baby dick Honda ones lol
75mm
Well here is the progress made so far. motor, tran's, and exhaust off. going to start the k-member swap this week or weekend.
Finally got started on my car again. OE k-member out along with steering part's. New bmr k-member installed. Found out had broken coil spring's oh well just more new part's to get.
well rack is figured out with the tie rod end's, coil spring's installed, brake's bleed back on the ground about to order steering shaft part's. hopefully will have the motor test fitted this week.
motor is in found out i have to remove the a/c heater box. found a non a/c box. plus trying to figure out where to mount the turbo and to run the pipe's.
I would like some suggestion's on what transmission to use. I would like to keep it streetable so i am thinking ether a th350 or a th400
Grr;325400 wrote:
mostly drag car with a turbo LSx i would HAVE to vote 'glide, they are absolutely not unstreetable. In fact with decent power they are much more streetable than a 3 speedDid Zach notice much of a difference when he swap from the th350 to a glide?
the best thing i have done aside the V8 is the glide
what does your car weigh? i am right at 3k with me in it
atleast for me it works better on the street, it helps put the power down and manage traction
gary rode in it on the street on the same power it was going lower 9s and can vouch for how well it hooks
plus it loads up and gets me full boost instantly, and i can still way overpower myself on the line when on the Brake
another thing is i have a remote fluid cooler with electric fan..... with the 350 that thing would run about all the time when driving/beating
with the glide i think it has kicked on twice, but alot of that could do with the converter too
I looked at my buddies glide and found out it would not work at this moment. I'm planning on running what i have for the rear suspension for now to keep the cost down
But once I do like you did Zach build my 6.0 and make it more of a track car than i will go with a glide. But now i have made progress. Got the old a/c heater box out and installed the non a/c box. Got the exhaust manifold's modified today and cut the idler arm bracket out and installed a plate over the hole. Also started the hotside exhaust pipe and kinda got the downpipe figured out. Hopefully have the hotside done this week. -
Well made some more progress today got the hotside tack welded and figured out.
It's a gt-45 ( 70mm ) if i remember. It was free i'm planning on upgrading after it get this set-up done. I started looking at an S400 75mm with a T-4 flange. But i'm open to suggestion's
Overall it's a win-win.
