  4. Car Updates / Progress
  5. My project
My project
70 Posts 13 Posters 21.1k Views
  • legacy-user-3898L
    legacy-user-3898L
    legacy-user-3898
    I looked at my buddies glide and found out it would not work at this moment. I'm planning on running what i have for the rear suspension for now to keep the cost down 😞 But once I do like you did Zach build my 6.0 and make it more of a track car than i will go with a glide. But now i have made progress. Got the old a/c heater box out and installed the non a/c box. Got the exhaust manifold's modified today and cut the idler arm bracket out and installed a plate over the hole. Also started the hotside exhaust pipe and kinda got the downpipe figured out. Hopefully have the hotside done this week.
    • legacy-user-3898L
      legacy-user-3898L
      legacy-user-3898
      Well made some more progress today got the hotside tack welded and figured out.
      • DaveHD
        DaveHD
        Looks good, what turbo is that?
        • legacy-user-3898L
          legacy-user-3898L
          legacy-user-3898
          It's a gt-45 ( 70mm ) if i remember. It was free i'm planning on upgrading after it get this set-up done. I started looking at an S400 75mm with a T-4 flange. But i'm open to suggestion's
          • DaveHD
            DaveHD
            With a relatively big cube motor like that, I'd go with a T6. It leaves you a lot more options in the future if you decide to upgrade.
            • zbrownZ
              zbrownZ
              yeah if you have the room build it around a t6 footprint
              looks good!
              • legacy-user-3898L
                legacy-user-3898L
                legacy-user-3898
                I really don't know if I will have the room for a T6 unless i cut into the fender well but then i might not have room around the hood. It's kinda tight around the turbo right now plus i will not have room for the down pipe. We were able to get 3.5 inch to fit right and i really don't want to cut into the frame that much. I even think 4 inch would be tough to do.
                • legacy-user-3898L
                  legacy-user-3898L
                  legacy-user-3898
                  well not much progress as of late. just a lot of ordering of parts. but i can say christmas is going to come early this year as everything i ordered should be here by next tuesday. then next week while i'm on vacation i will work on the fuel system and possibly pull the motor out and swap out the oil pan and weld in the drain for the turbo. i also might start some of the wiring
                  • legacy-user-3898L
                    legacy-user-3898L
                    legacy-user-3898
                    Well christmas came early for me (transmission, most of my fuel system part's, starter, and misc part's i ordered). plus my buddy got his converter back and his engine for his race car. so it has been a good week for both of us 🙂
                    • legacy-user-3898L
                      legacy-user-3898L
                      legacy-user-3898
                      Fuel system is almost done just have the cross over left to do. Will get that done tomorrow and then pull the motor out and swap out oil pan's and work on the oil drain for the turbo. Than after my torque converter show's up put it all back together and figure out radiator hose's and heater hose's
                      • legacy-user-3898L
                        legacy-user-3898L
                        legacy-user-3898
                        Ok here is an update with some picture's. Transmisson is a th-350 with a b&m stall
                        • legacy-user-3898L
                          legacy-user-3898L
                          legacy-user-3898
                          well it's been a while since an update. computer wiring done under the hood and radiator ordered and modifed
                          • legacy-user-3898L
                            legacy-user-3898L
                            legacy-user-3898
                            Well it's almost done. just waiting on b.o.v. got it running last week.
                            [legacy attachment 6929]
                            • legacy-user-3898L
                              legacy-user-3898L
                              legacy-user-3898
                              Got my b.o.v. today. But i was able to drive it before i got home and saw that it showed up. Car run's really good considering it's not tuned at all. I also have traction issue's as soon as it start's to boost the tire's break loose.
                              • legacy-user-3898L
                                legacy-user-3898L
                                legacy-user-3898
                                I have been out driving it. Now to finish the exhaust and install the part of the cage
                                [legacy attachment 6934]
                                [legacy attachment 6935]
                                • kylushK
                                  kylushK
                                  kylush
                                  looks sweet!
                                  1998 Z28 Camaro
                                  • RexwagonR
                                    RexwagonR
                                    sounds like a fun ride. how much power you think your making?
                                    is your name doug?
                                    • legacy-user-3898L
                                      legacy-user-3898L
                                      legacy-user-3898
                                      I really have no idea on how much power it is making yet. Only seeing about 5-6 psi right now. Yes my name is Doug
                                      • seanzi88S
                                        seanzi88S
                                        seanzi88
                                        Awesome job man!
                                        • legacy-user-3898L
                                          legacy-user-3898L
                                          legacy-user-3898
                                          Almost done with the exhaust. 3.5in all the way back.
